If you have a 96 I need your input - FirebirdV6.com/CamaroV6.com Message Board
  • If you have a 96 I need your input
    If it's not too much trouble for you to take your pcm out. It takes 5min. Can you either take a close up pic of the board or describe it in detail? I need to know:
    1. Is the board coated with clear plastic? You will know what I mean if it is.
    2. Tell me all the numbers on that flash chip. It's the one that says"intel flash" on it. A measurement of the chip will also help.
    I also need to know the month and year that your car was made. It's on your door. Some were made in September of 95, but are classified as 96.
    Thanks for the input.
    Dom, I can do this for you tomorrow (daylight) [img]smile.gif[/img]
    But what for?
    Justin<br />1998 Camaro Z28 M6<br />1985 Pontiac Fiero M5<br />1999 Pontiac Firebird A4<br />AIM: FTBvideo<br />\"Music\'s what I need to keep my sanity!\" --S.A Martinez, 311
      My chip seems to be totaly different from 97 chip. Just want to make sure it's for all 96s and not just the ones made in 95 like mine. It was very hard to remove and install again compared to the 97s. Also the code was much different.
      [ March 13, 2002: Message edited by: Dom ]</p>
        once i get it running i'll be glad to, but thats not until probably sunday or so
        Josh<br />96 Red Firebird <br />SLP intake, zex nitrous 75 shot(for sale), purge kit, MAC lca + phr, Jamex springs, flowmaster 80 series, ES tranny bushing, SCR subframe conectors, Harlan shiftlight, A/F guage, MSD dis-4, Accel wires w/ NGK tr6\'s, foglights, stereo, zexel torsion LSD, Walboro 255 pump, and more.<br />Looking for: 1le ds, nx wet kit + accesories
          Once I get a chance to look at it I will let you know [img]smile.gif[/img]
          1996 Y87 Camaro, 175.0 rwhp, 211.6 rwtq.....1/4 15.500@88.54 &lt;----- Needs work!!<br />-CAI, Custom bent S-Pipe, LS1 I-Pipe, Flowmaster 80 series, !MAF, manual fan switch, relocated trunk pop switch, 180 degree t-stat, More to come!<br /> <a href=\"http://camaro.wbisolutions.com\" target=\"_blank\">http://camaro.wbisolutions.com</a> <p>WANTED!!! Naked and handcuffed!
            The reason is this....
            Dom is a local friend of mine.. so he allowed me to read his PCM for my collection of information and to help with my project.
            Well, all of his circuitry is covered with a small layer of silicone. If I recieve ANY PCM's that have this, I am sorry but it is too much of a PITA to work on them. Chances are only a few of the 95/96 models have this problem. I have read 3 97 PCM's and they do not have this problem.
            The chip itself is also different which means more experimentation to figure out what is what.
            The PCM did have the markings of a 95 PCM though so I figure its just a GM flaw during the OBD-I to OBD-II transfer.
              i will check mine when i get home from work around 5:30 central. :cool:
              96 wht. firebird 5sd. rk sport headers,3in.catco, spintech catback,CAI,FRA,3.42/lsd 180*t-stat, centerforce dual friction clutch, ls1 driveshaft, polyurethane trans. mount.<br />01 blk. z28 m6, borla exht, lid, k<br />+n, sfc., chrome 18in. y2k c5 wheels.
                Well if you read 3 97 pcm and they didnt have that problem and you say the chip from doms 96 is different than the 97 i hope not all 96 chips are different. do i have to take the 4 hex bolts out to see the numbers on the flash chip?, or is the numbers on the outside of the case?
                  You have to take the cover off. You want to look at the board and size of the chip also.
                    Are you still looking for info on this? I can check when i go home this weekend.
                    <b>Matt</b><br /><a href=\"http://www.cardomain.com/member_pages/view_page.pl?page_id=377225&page=1\" target=\"_blank\">\'96 Camaro Z28 M6</a><br /><a href=\"http://www.cardomain.com/member_pages/view_page.pl?page_id=377225&page=3\" target=\"_blank\">\'96 Camaro M5</a>
                      Dom, I have confirmed other 96 owners have the same PCM as you. Even with the gel/rubber coating.
                        I got that 97 one from Danny. Hope it works.
                          So do this rule out the 96 PCM's from hopes of programming by magnus?
                            most likely yes.. its just too risky.
                            If the 97 PCM works on Dom's car, and you still wish for custom affordable programming by me, I suggest you buy a 97 PCM from a junk yard..
                            I might also stock some 97 PCM's for this very reason.
                              Hey, i don't blame you. I have no need for programming at the moment. I was just looking to help with the info on the 96's. How much would a PCM usually run from a junkyard?
                              Keep up the good work magnus. Seems like you are making some nice progress.
                              EDIT: I was just thinking of the changes that come to mind from 96 to 97 and, DRLs, guage cluster (digital odometer), and taillights were the few that came to mind that might have anything to do with the PCM and possible wiring changes. I am not sure at all how this would affect the PCM. These seem like very trivial things so i am not even sure if they deal with the PCM, but just some things that came to mind. I am sure you have already thought of these though. Good luck!
                              [ March 21, 2002: Message edited by: Amped96 ]</p>
