Need some specs - FirebirdV6.com/CamaroV6.com Message Board
Need some specs
  • Need some specs
    1. I need the base circle measurement.
    2. Our rockers are 1.60 exactly?
    3. Stock pushrod length.
    4. Stock springs diameter.
    i checked my haynes and it did not have anything sorry i tried
    1998 Jet Black Trans-am M6 T-tops<br />\"Ask, and it shall be given you; seek, and ye shall find: knock and it shall be opened unto you:-Matthew 7:7<br />Old car<br /><a href=\"http://matthew27529.tripod.com/getsome\" target=\"_blank\">http://matthew27529.tripod.com/getsome</a><br />NEW CAR<br /><a href=\"http://garnerebel.tripod.com/\" target=\"_blank\">http://garnerebel.tripod.com/</a>
      What engine?
          My base circle is ~ 1.237.. measured with a caliper.
          Stock pushrod lenght is 7.033, I will confirm this.
          Our rockers are stamped pieces, they are not perfect. ~ 1.60
            Can you measure the spring with the caliper also? You're probably busy at work at usual and don't need this bs, but when you get time.
