o NO... Car Probs After Cam Install - FirebirdV6.com/CamaroV6.com Message Board
  • o NO... Car Probs After Cam Install
    Ok, so this is whats up. I install the cam and rockers tonight. All is well when i start the car.. i do hear clicking but that just means i need to readjust the valves, this may be the problem.. but ill continue. so after letting it idle at 2k for 30 min i go and take it for a test drive. the first 2-4 minutes were perfect.. no misses and lots of power... but after that my car stumbled and stumbled and i couldnt keep the damn thing running. if i would stomp it... it would accel but stumble HARD on the way up. Example..
    my rpm gauge as follows.
    1k...stumble.. 1.5k... stumble etc.. it was like it got power and then lost it and make my car die... but then awakened again. Im puzzled. Oh, and i also got a service engine soon light.
    As i was told this cam is computer compat. im thinkin this... the cam isnt computer compatable... or i broke something expensive... or my valves are causing the whole problem. i dont know. anyone know what is up with my car?
    For Sale<p>Mods so Far:<br />Tb Coolant Bypass, NGK Vpower Plugs, Accel 8mm Wires, Gutted Cat, TransAm Muffler, K&N FIPK, Crower Baja Cam, Comp Cams Magnum Rocker Arms 1.52 Ratio, Ported Throttlebody, Ported Intake Manifold, 3.73s and Auburn LSD, Yellow Underbody Neons, Milled Heads, Pacesetter Headers, TransGo Shift Kit, 1 Piece DS, Accel Coils, Rk Sport Air Temperature Module<p>Soon Mods:<br />Nos 5175, Rims, Stage 2 Jet Chip, Jet Underdrive Pullys, Strut Tower Brace, Subframe Connectors, Speed Calibrator, Lowering Springs
    What engine, what cam, what rockers?
    Stupid me, I see the sig now.
    How loose are the rockers or how bad is the tapping? You sure you have everything back on right? ANy SES codes?
    [ March 22, 2002: Message edited by: stagen ]</p>
    94 Quasar Blue Z28<br /><a href=\"http://www.9t4z28.com\" target=\"_blank\">http://www.9t4z28.com</a><br /><a href=\"http://www.9t4z28.com/Dyno1.htm\" target=\"_blank\">http://www.9t4z28.com/Dyno1.htm</a>
      if the rockers are fugged up enough it could cause that...scan the ses for starters...
        Maybe you fried a plug wire somehow ... hope for the best ... good luck ... scan the SES ...
        -Rob
          ok, well i went to my family owned mechanic shop and did the diagnosis. i put it on the rack and scanned for codes. i got a map sensor code. which means i have a vac leak. so i checked it all out and turns out i have a HUGE vac leak. crap. so anyways im gonna go ahead and buy the entire vaccum system piping and re do it all. thanks for yalls help.
            Try this first: Get a short length of hose. Maybe 3 feet. Start your engine, put the hose to your ear then put the other end in and around the engine. Trust me, you'll find the leak if it's there. You'll hear a big difference in the sound. Try around your EGR valve.
            When I put mine back together I had my EGR valve on backwards and had a huge leak. The hose found it :)
              <blockquote>quote:</font><hr>Originally posted by stagen:
              Try this first: Get a short length of hose. Maybe 3 feet. Start your engine, put the hose to your ear then put the other end in and around the engine. Trust me, you'll find the leak if it's there. <hr></blockquote>
              i think stacey has an obession with this little tube idea ;)
                <blockquote>quote:</font><hr>Originally posted by hawgs:
                <hr></blockquote>
                I agree!!!! but it does work.. :D
                  yeah, ive also found a exhaust leak from my headers. looks like i need to retighten the bolts again. yay. im gonna tear the engine down again tomorrow and re tighten my rockers. ive found that spinning the pushrod until you cant spin it and then tightening it a half a turn will make your rockers perfect. i did the up and down method with the pushrod and then 1/4 a turn. much too loose.
                  ill try the hose method and see what i can find.
                  thanks
                    <hr></blockquote>
                    At least I stuck it in my ear to listen for leaks. I'm not even going to mention what Kris did.
                    Alos make sure that you have enough clearance between each rocker when you tighten them.
                      He does like his hose but It works alls good though. HAHA
                      By the way what did I do. If it is converting a wet to dry then dont comment
                      [ March 23, 2002: Message edited by: slacker69 ]</p>
                      <b><a href=\"http://www.sick-sixx.com\" target=\"_blank\">SICK-SIXX MEMBER</a></b><br />NA 14.345 with a 1.863 60 foot<br />Nitrous 13.03@99.5 with a 1.63 60 foot<br /><br />2000 Camaro 3.8L A4: USE TO HAVE Comp Cam 210/220 .535/.547 113lsa 111 I/C, Port and Polished Heads, NX Wet Kit 100 Shot, CPRA made by CP, RK Sport Headers
                        LOL - you created a grenade that for your sake didn't get it's PIN pulled..
                          thats freaking hilarious stacey must be bored in london to think of all this
