I have a 98 3.8 and i was thinking about a cam install. I am on a tight budget will getting the cam that works with stock heads (210/214 .45/.45 112) do any good or will it be better to do heads and cam etc. also what kind of gas mileage do you get when you start adding cams, ported heads etc. the car is a daily driver and needs to run good.
my biggest problem is that the engine has a little over a hundred thousand miles. will a cam put excessive strain on the motor. when installing a cam is the engine apart that much that you should just rebuild it?
did anyone ever create a cam install guide
[ February 20, 2003: Message edited by: marcus_3050 ]
[ February 20, 2003: Message edited by: marcus_3050 ]</p>
