What all is needed I do know i need a different cam and solid lifters but what else is needed. I hear something about adjusting the rockers. do our rockers allow for adjustment. What else is needed and what is to gain from it. I hear alot about solid roller setups on ls1's makin some real power
Lets talk solid roller setups
<b><a href=\"http://www.sick-sixx.com\" target=\"_blank\">SICK-SIXX MEMBER</a></b><br />NA 14.345 with a 1.863 60 foot<br />Nitrous 13.03@99.5 with a 1.63 60 foot<br /><br />2000 Camaro 3.8L A4: USE TO HAVE Comp Cam 210/220 .535/.547 113lsa 111 I/C, Port and Polished Heads, NX Wet Kit 100 Shot, CPRA made by CP, RK Sport HeadersTags: None
It is extremely costly and a hell of alot of work.
Go to easternfbody.com A few of those guys have solid roller set-ups making bad *** power.
Zach97 Mustang V6 Auto<br />PI 3000 Converter-Aluminum DS-4.10\'s-FMS T-lok-ASP UD Pulley-Flowmaster Duals-BBK 65mm TB-Stage 3 Upper and Lower Intakes-24lb Injectors-155lph fuel pump-Custom Dyno Tune-NX 75-100 shot<p>Best times: 15.1@87mph on motor<br />13.42@98 on nitrous
a solid roller will make WAY more power than any other type of cam...but if you dont have shaft rockers you will have to set valves very often, you can buy shaft rockers for LS1's from T&D Machine so they can set them once and not worry about them, but i dont think there are any for the 3.8...you can call my dad and get him to talk to T&D and see if the shaft rockers from the Race buick v6 heads will fit the 3.8, he is one of two dealers in Texas of T&D Machine products, its Abbott Racing Heads and the number is 915-558-2841...his name is Kenneth...
[ February 22, 2003: Message edited by: WickEdSix9838 ]</p><b>Black</b> 1998 Pontiac <i>Firebird</i> A-4 swap<br />271.4rwhp/259.4rwtq NA<br />13.30@102.44 <br /><a href=\"http://www.freewebs.com/wickedsix98\" target=\"_blank\">www.freewebs.com/wickedsix98</a>
You also need to machine the block in the lifter area to clearance for the pieces that connect the lifters together (can't remember what these are called)
I have a bud with a 396 solid roller LT1 and have been talking to him about the setup. It will cost you a lot of $$ and probly more time than it's worth because it's not something that anyone has done before on a 3.8 (that I know of)Michael Huff<br />92 RS, 98 V6, 97 SS, 00 Z28 <br /> <a href=\"http://www.carolinafbodyclub.com/\" target=\"_blank\">http://www.carolinafbodyclub.com/</a>
<blockquote>quote:</font><hr> You also need to machine the block in the lifter area to clearance for the pieces that connect the lifters together (can't remember what these are called) <hr></blockquote>
link bars<b>Black</b> 1998 Pontiac <i>Firebird</i> A-4 swap<br />271.4rwhp/259.4rwtq NA<br />13.30@102.44 <br /><a href=\"http://www.freewebs.com/wickedsix98\" target=\"_blank\">www.freewebs.com/wickedsix98</a>
