PCM can learn... for real...!!! - FirebirdV6.com/CamaroV6.com Message Board
  • PCM can learn... for real...!!!
    I switched to 3.42' from 3.08's just recently. When I first picked up the car the 1-2 was a 4500rpm evertime at WOT. I have noticed that it has seemed to be getting better for whatever reason.
    I just lift Discount Tire have my tire balanced and rotated. Then went down a nice open strech of hwy and dead stopped. I did not stall it I just WOT from a dead. The 1-2 shift was at 5600rpm and so was the 2-3 shift was the same. By that time I was well over 100mph and back in traffic where I slowed down.
    I got one more good straight on the way and the 1-2 shift was around 5700rpm this time...!!!
    I have put around 275 miles on the new gears, and it seems that the PCM has "learned" that they are there and changed the shift points.
    This is great...!!!!
    Does this mean that my speedo is closer to right now as well...??
    And, has anyone else experienced this...??? I may not need programming for the PCM if this is the way the new gears are going to shift all the time.
    just adding \'um \'till I trap 12.393...
    He** yea man that is awesome! I'm getting 3.42's soon lol.. I doubt it though, what your mileage and stuff. But that would be really cool if it did that :eek:
    RedLineVSix <br />95 Patriot Red Trans Am, M6, 3.42\'s,no rear tires<br />(SOLD!)97 Silver Camaro 3.8 Liter A4 3.42 + LSD, 1pc DS, and one messed up speedo :)
      :rolleyes: [img]graemlins/bs.gif[/img]
        <blockquote>quote:</font><hr>Originally posted by Jason Morgan:
        :rolleyes: [img]graemlins/bs.gif[/img] <hr></blockquote>
        Unfortunately I'm going to have to agree with Mr. Morgan. I'm not gonna call BS, but I'm just going to say that I think you are mistaken.
        Matt<br />2000 Firebird<br /><br /><a href=\"http://www.fullthrottlev6.com/forums/index.php?\" target=\"_blank\">FullThrottleV6.com</a>
          WOT shift points aren't that bad after going from 3.08 to 3.42. I didn't notice that much of a change. You're still gonna notice quicker shifting during cruise, and your speedo is still off. The PCM will not relearn gear changes.
          <b>1998 Firebird 3800 Series II, A4</b><br />Direct-Flo Lid,K&N Filter,DEE TB Spacer,TPS-TEC,ZZP Mini-AFC,Raised and Cutout Airbox 7mm,BMR STB & Boxed LCAs,KYB AGX Shocks,Drilled/Slotted Rotors,180* Thermo,2.5\" Catco Cat,Dynomax 2.75\" custom catback,Kumho Ecstas/245,Jet Stage 2,3.42,Edge Racing 2870 Stall,B&M Tranny Cooler,B&M Deep Tranny Pan,LSD,AAM Girdle,1LE DS,NX Wet Kit,MSD DIS-4,MSD Blaster Coil Packs,Taylor Spiro Pro 8mm Wires,NGK TR6\'S gapped .045,ZZP UD WP Pulley,SLP Fan Switch,TT II\'s<br />N/A: 15.6342 @ 88.44 (On stock converter. Strugglin\' to beat it.)<br />Nitrous 50 Shot: 14.7463 @ 93.49
            the pcm will learn some things, unfortunately gears is not one of them :(
            6s.......under the hood or under the belt, they just dont cut it.
              Well, If my car will still shift at 5600-5700rpm's duruing each gear I am not in nearly as big a hurry to the get the PCM reprogramming. So maybe I am wrong, but what would explain the WOT 4500rpm shift when I first picked up the car..??
              So I am not trying to start a flame thread, I am just simply reporting what I have witnessed over the last few days. I will try to check the speedo tomorrow to see how much it is off.
              Anyway, I have noticed a small drip from the rearend. Should I get the gasket for the diff or just use the silicone to reseal the diff cover....??
                id say do it the right way: gasket
                Visit My F-Body Page
                  <blockquote>quote:</font><hr>Originally posted by Loochy88:
                  id say do it the right way: gasket<hr></blockquote>
                  The guy that did my gears refused to use a gasket. He used silicone.
                    there is nothing wrong with silicon. dont sweat it. it is good for your application as well as breasts :D
                    for real, i have silicon also in a few places. but then what do i know???? my mechanic put it there.
                      I use gaskets
                      <b><a href=\"http://www.sick-sixx.com\" target=\"_blank\">SICK-SIXX MEMBER</a></b><br />NA 14.345 with a 1.863 60 foot<br />Nitrous 13.03@99.5 with a 1.63 60 foot<br /><br />2000 Camaro 3.8L A4: USE TO HAVE Comp Cam 210/220 .535/.547 113lsa 111 I/C, Port and Polished Heads, NX Wet Kit 100 Shot, CPRA made by CP, RK Sport Headers
                        gaskets are the correct way. ive NEVER had a leak. get the feldpro gasket, high quality.
                          Drove to auto parts store.
                          Bought a $3.19 gasket.
                          Drove home.
                          Put car on jack stands.
                          Pulled diff cover, on gasket.
                          Cleaned cover and housing.
                          Added a GASKET to the diff cover.
                          Tighten all bolts.
                          Stalled it to 2400RPMs, run a 12sec 1/4 (well maybe a 15).
                          Ran car over 100mph.
                          Came home.
                          Looked at diff, no leak.
                          I love [img]graemlins/bs.gif[/img] mech shops...
                          if you want something done right spend 4 hours on your back...!!! [img]graemlins/rofl.gif[/img] [img]graemlins/rofl.gif[/img]
                            <blockquote>quote:</font><hr>Originally posted by Texas4ever:
                            Drove home.
                            Tighten all bolts.
                            Came home.
                            <hr></blockquote>
                            for me it would have been:
                            drive to store
                            buy th e wrong $10 gasket
                            drive home
                            jack up car
                            strip some bolts
                            find out i bought wrong gasket
                            walk to autozone
                            come home
                            put gasket on
                            strip some more bolts
                            drive around
                            check for leaks
                            find a leak
                            go to bed crying
                            thats the way things would work out if i tried to do anything myself.
                              <blockquote>quote:</font><hr>Originally posted by nino:
                              drive to store
                              drive home
                              jack up car
                              strip some bolts
                              walk to autozone
                              come home
                              put gasket on
                              drive around
                              check for leaks
                              find a leak
                              go to bed crying
                              <hr></blockquote>
                              [img]graemlins/rofl.gif[/img] [img]graemlins/rofl.gif[/img] That's me right there [img]smile.gif[/img]
