3.4 Reprogramming - FirebirdV6.com/CamaroV6.com Message Board
3.4 Reprogramming
  • 3.4 Reprogramming
    Here is an email I got from fastchip.
    Hello,
    Those 3.4L V6 engines normally gain 15 to 16 hp at the wheels, and 25ft lbs more torque. I also remove the top speed limiter, turn the cooling fan on sooner to improve cooling, and firm up the shifts on the automatic cars. We can also program for different gears or tire sizes.
    That car has a reprogrammable PCM (computer), not a chip you can just plug in. The only way I can do one is to have the vehicle
    or it's PCM here for the reprogramming. If you are too far away to drive here (Tulsa, OK) you could pull the PCM and ship it to me for reprogramming. I can normally turn one around within 48 hrs. If you drove here I would do it while you wait. The cost would be $300.00, +
    freight if shipping is involved.
    We can also send you an exchange PCM (if we have a "core" on hand at the time), already reprogrammed for your vehicle. If we do that we need a refundable $500.00 "core charge" until we get your other PCM back here to replace the one we sent you. We would also need your vehicle's vin, as it goes in the PCM. If you used a Visa or
    Mastercard, and got the other PCM back here in less than two weeks, to replace the one we sent, you wouldn't even see the core charge on your bill. If you failed to get it back here in two weeks, you would then own two PCMs. If interested, please call us @ 918-446-3019.
    Thanks, Ed
    At 12:14 PM 2/21/03 -0600, you wrote:
    Is the top speed limiter the only mod you have for 3.4L camaros? Can you reprogram for a 3.73 gear change as well?
    Harry Garvin
    I thought this would be of some help for you guys looking for reprogramming and getting rid of that dumb speed limiter. :cool:
    1994 Chevrolet Camaro 3.4L A4 (160hp 200tq)<br />2006 Nissan 350Z 3.5L M6 (300hp 260tq)
