I was wondering if our fuel setup has a vacum return from the tank or if it is like the ls1's? This is about a 98 3.8
Does anyone know what type of fuel system we have?
Msd wires,Summit coils,Cuctom CIA&longtubes 2.5inch w/side exit,Cam,Heads & Intake,30# injectors,reprogrammed computer,3400 edge Converter, 3.73\'s&LSD,Edlebrock torque arm, SLP LCA\'s,Jegs panhard bar,16 inch nittos Best ET 14.374 @94 <br />Best 60\' 1.91Tags: None
Yes.
Three lines go to the fuel rails. Fuel delivery, fuel return, and one for the carbon canister purge. A fourth line runs from the tank to the carbon canister located in the driver side rear quarter panel, behind the tire.Big cam. Big stall. Big nuts.<br /><br /><a href=\"http://www.streetlethal.net/vids2/joenastycam.MPG\" target=\"_blank\">Idle/Rev Clip.</a>
ThanksMsd wires,Summit coils,Cuctom CIA&longtubes 2.5inch w/side exit,Cam,Heads & Intake,30# injectors,reprogrammed computer,3400 edge Converter, 3.73\'s&LSD,Edlebrock torque arm, SLP LCA\'s,Jegs panhard bar,16 inch nittos Best ET 14.374 @94 <br />Best 60\' 1.91
