I went to the Hypertech website and saw there was only a programmer for 2000-Up Firebirds. Will this one work with the 99 Birds? I wanted to recalibrate the PCM when I install the LSD with 3.42's. I wanted to avoid having to get the SLP processor because with the Hypertech I could use it for other stuff as well.
1999 Firebird Hypertech Programmer?
<b>.::[ 0 ]::.</b><br /><b>1997 Camaro 3800 II M5</b> (30th edition)<br />[]B&M Ripper Shifter<br />[]Proform Shift Light<br />[]SLP Cold Air<br />[]Dynomax Exhaust<br />[]Richmond 3.73\'s<br />[]Zexel-Torsen LSD<br />[]180* Thermostat<br />[]Tail Blackouts<br /><a href=\"http://photos.yahoo.com/skyracer_x\" target=\"_blank\">pics</a>Tags: None
AFAIK, they're still working on the 98s and 99s. Don't think a 2000 would work for a 99, as the exhaust manifolds might change some of the effects.
MattMatt
1998 Mystic Teal Camaro M5
I thought it has been said on here, that if you have a '99, you can swap a '00 pcm into it. Then you can use the hypertech. You may want to search and see who has said this, but I'm pretty sure it's been brought up at least a couple of times.\'98 A4 Camaro v6->v8 conversion, and STS kit next<br />v6: 13.6 Powerdyne, 13.2 150 shot, 13.8 120 shot, 14.3 85 shot, 15.7 stock<br />v8(na): 12.18@113, 392rwhp<br />Moderator on <a href=\"http://www.mtfba.org\" target=\"_blank\">www.mtfba.org</a> and <a href=\"http://www.frrax.com\" target=\"_blank\">www.frrax.com</a> (Road Race & Autocross)<br /><a href=\"http://community.webshots.com/user/johnduncan10\" target=\"_blank\">Car pics</a>, <a href=\"http://www.trscca.com\" target=\"_blank\">TN Region SCCA</a>
well i am in the process of buying a 00 pcm for my 99, ill let you know how it goes98 Jeep Grand Cherokee 5.9 Limited<br /><br /><br />MODS:<br />180* t-stat, K&N FIPK, mopar ECU,<br />mike leach long tube headers+3\" y-pipe, 3\" all the way out flowmaster 50 series, mopar magnum 2bbl m1 intake manifold, APS 52mm throttle body, powerslots, 2 JL 10w3\'s
