Ok I got the advise on my other posting. I'm getting ready to do a complete rebuild on my engine. I'm planning on using 12 to 1 compression, providing I can get it to work on 92 octane, 1.8 rocker arms, high energy valve springs and retainers. A level 4 port and polish with a 3 angle valve job. I'll be using a vigilante 2700 stall coverter, and a 12 bolt posi. What would be the best cam, to get the most hp and torque out of this set up?
Ok new message still regarding cams
2000 Firebird. Whisper Lid, True duals, TSP mail order tune, Built Tranny , TCI 2800 stall verter, B&M tranny cooler, Eaton LSD, 3.42 gears. Current best ET. 15.232 89.09 MPH 2.175 60ft on stock 3.42\'s and open diff.<a href=\"http://www.geocities.cTags: None
<blockquote>quote:</font><hr>Originally posted by camaro_zach:
WOW if you are going that all out get a damn 224/224. lol. good luck with your project. ;) <hr></blockquote> Hey I want 13's or better all motor..lol2000 Firebird. Whisper Lid, True duals, TSP mail order tune, Built Tranny , TCI 2800 stall verter, B&M tranny cooler, Eaton LSD, 3.42 gears. Current best ET. 15.232 89.09 MPH 2.175 60ft on stock 3.42\'s and open diff.<a href=\"http://www.geocities.c
Just wondering? How are you gonna get 12 to 1 compression to work on 92 octane? I am by no means an expert on compression and minimum octane ratings, but here is a chart I picked up concerning ratios and minimum octane levels:
Desired ratios and minimal octane levels
9:1=90, 10:1=94, 11:1=98, 12:1=102, 13:1=106, 14:1=110
I have a friend who has an LT1 that was shooting for a 11:1 ratio not taking into account the octane levels. His car will flat out not run on pump gas.<b>1998 Firebird 3800 Series II, A4</b><br />Direct-Flo Lid,K&N Filter,DEE TB Spacer,TPS-TEC,ZZP Mini-AFC,Raised and Cutout Airbox 7mm,BMR STB & Boxed LCAs,KYB AGX Shocks,Drilled/Slotted Rotors,180* Thermo,2.5\" Catco Cat,Dynomax 2.75\" custom catback,Kumho Ecstas/245,Jet Stage 2,3.42,Edge Racing 2870 Stall,B&M Tranny Cooler,B&M Deep Tranny Pan,LSD,AAM Girdle,1LE DS,NX Wet Kit,MSD DIS-4,MSD Blaster Coil Packs,Taylor Spiro Pro 8mm Wires,NGK TR6\'S gapped .045,ZZP UD WP Pulley,SLP Fan Switch,TT II\'s<br />N/A: 15.6342 @ 88.44 (On stock converter. Strugglin\' to beat it.)<br />Nitrous 50 Shot: 14.7463 @ 93.49
<blockquote>quote:</font><hr>Originally posted by AMinor65:
9:1=90, 10:1=94, 11:1=98, 12:1=102, 13:1=106, 14:1=110<hr></blockquote>
According to this chart, shouldn't we be running 92 octane with our 9.4:1 compression? ;)
Matt
[ March 02, 2003: Message edited by: 98Camaro3.8 ]</p>Matt
1998 Mystic Teal Camaro M5
I'm also curious to see how you can run 12:1 compression on 92. I just had my engine built w/ forged pistons running 10:1, and they said thats the max they could do and still have it run on 92. I know timing plays a role, but it seems you'd have to back of the timing so much it wouldn't be worth it...correct me if I'm wrongYou want to know what\'s on my car? Tough luck!
<blockquote>quote:</font><hr>Originally posted by 98Camaro3.8:
Matt
[ March 02, 2003: Message edited by: 98Camaro3.8 ]<hr></blockquote>
I thought about that too when I first saw the chart. To be honest with you, I don't know. Maybe the chart is supposed to be like a "rule of thumb". I've seen it posted a few places.<b>1998 Firebird 3800 Series II, A4</b><br />Direct-Flo Lid,K&N Filter,DEE TB Spacer,TPS-TEC,ZZP Mini-AFC,Raised and Cutout Airbox 7mm,BMR STB & Boxed LCAs,KYB AGX Shocks,Drilled/Slotted Rotors,180* Thermo,2.5\" Catco Cat,Dynomax 2.75\" custom catback,Kumho Ecstas/245,Jet Stage 2,3.42,Edge Racing 2870 Stall,B&M Tranny Cooler,B&M Deep Tranny Pan,LSD,AAM Girdle,1LE DS,NX Wet Kit,MSD DIS-4,MSD Blaster Coil Packs,Taylor Spiro Pro 8mm Wires,NGK TR6\'S gapped .045,ZZP UD WP Pulley,SLP Fan Switch,TT II\'s<br />N/A: 15.6342 @ 88.44 (On stock converter. Strugglin\' to beat it.)<br />Nitrous 50 Shot: 14.7463 @ 93.49
Toyota Celica GT-S has 11.5:1 compression and they can run 6lbs. of boost on 91 octane and stock internals...\'97 Pontiac Firebird A4 3.08/open<br />Best 60ft.: 2.411 Best 1/8: 10.262 @ 69.726 Best 1/4: 15.941 @ 87.48<br />Mods: SLP CAI, Loudmouth, Test Pipe
I have a friend who has an LT1 that was shooting for a 11:1 ratio not taking into account the octane levels. His car will flat out not run on pump gas.<hr></blockquote> I'm still working on that with the shop that is doing the rebuild, they suggested 12 to 1, I was thinking 10 or 10.5 myself. Since my car is my main means of transport. I'm going to get more in depth on it. The orignal intimdator concept car ran 13 to 1's on 92 octane, so I have no idea.2000 Firebird. Whisper Lid, True duals, TSP mail order tune, Built Tranny , TCI 2800 stall verter, B&M tranny cooler, Eaton LSD, 3.42 gears. Current best ET. 15.232 89.09 MPH 2.175 60ft on stock 3.42\'s and open diff.<a href=\"http://www.geocities.c
<blockquote>quote:</font><hr>Originally posted by Rick M.:
Toyota Celica GT-S has 11.5:1 compression and they can run 6lbs. of boost on 91 octane and stock internals...<hr></blockquote>
You also have to take into account we have an iron block with iron heads, while the celica is all aluminum.You want to know what\'s on my car? Tough luck!
if you had aluminum heads and block you might could get away with 12:1 but your block and heads are iron the retain to much head and with 92 octain my *** you would need probly 110
your shop is stupid. find a new one if they dont know your heads and block arnt aluminum and that all they could take with 93 octain is 10.5:1 they are crazy and stupid find another shop
you can run a crap load of compression on 92 octane, did ya'll see the engine masters challenge in Popular Hot Rodding magazine?? there was a guy that ran 16:1 static compression on 92 octane pump gas...its in how the cam is ground, you can have a cam ground that will lower the dynamic compression by bleeding off the extra cylinder pressure to run pump gas, as to specs to get ground, you're gonna have to call someone w/more knowledge, but it is possible...
[ March 03, 2003: Message edited by: WickEdSix9838 ]</p><b>Black</b> 1998 Pontiac <i>Firebird</i> A-4 swap<br />271.4rwhp/259.4rwtq NA<br />13.30@102.44 <br /><a href=\"http://www.freewebs.com/wickedsix98\" target=\"_blank\">www.freewebs.com/wickedsix98</a>
LT1's also have reverse cooled heads. Again, the cooler heads prevent detonation which will allow a higher compression ratio.
As far as having the cam bleed off compression, isn't that defeating the purpose of running high compression?You want to know what\'s on my car? Tough luck!
