www.n2performance.com had an excellent article called Cylinder Heads and Power in their Lectures section. Pretty good reading, although not "light". Not specific to 3.8's or anything, but good none the less with alot of theory. Here 'tis Cylinder Heads and Power
Ron
I know - Camaro 67-02.. 2000 Camaro V6/A4 Black T-Tops<br />1969 Camaro 350/PG 12.69 @ 102.5 1966 Chevy II Wagon 283/PG Destined for NHRA stock eliminator.
