I'm getting a DTC 1676 and the check engine light keeps coming on in my Volvo V6 swap. I can't find ANY reference to this trouble code in my FSM. Anyone know what it might be?
DTC 1676
DTC 1676
Kelly \'GhoSSt\' Rosato<br />1996 Impala SS, 385ci LT4, 52mm TB, Quad1 headers, !Cats, !EGR, !AIR, Hooker Catback, SLP TC, UK3, UL0, GM CD changer, Onstar®, Homelink® Remote, lots of Fleetwood, Denali & 9C1 Stuff.<br />1998 Z28 Convertable (stock at the moment)<br />1993 Caprice 9C1, 406ci MPFI, overhead console, 8-way Riviera seats, DVD, CD Changer, etc..<br />1977 Volvo w/ 3.8l V6 from a 1998 FirebirdTags: None
Hi Kelly, hope the projects are going well.
Here's your DTC:
Drive by Wire-MIL Circ. Electrical MalfunctionKeith - Chicago<br /><a href=\"http://www.hptuners.com\" target=\"_blank\">HP Tuners - PCM Reprogramming</a><br /><a href=\"http://www.dxsoftware.com/magnus/\" target=\"_blank\">97 Firebird V6 to LS1 swap</a><br /><b>V8 9.967@132.78</b> 1.322 60\' NA Heads/Cam<br /><b>V8 10.295@128.48</b> 1.363 60\' NA Cam Only<br /><b>V8 10.987@119.31</b> 1.422 60\' NA Stock Internals<br /><b>V6 13.674@98.22</b> NA<br /><b>V6 12.394@104.91</b> N20 100HP
With DTC 1xxx they are manufacture options as opposed to 0xxx so check what I posted.. that's from an audi list though, it may be different for GM.Keith - Chicago<br /><a href=\"http://www.hptuners.com\" target=\"_blank\">HP Tuners - PCM Reprogramming</a><br /><a href=\"http://www.dxsoftware.com/magnus/\" target=\"_blank\">97 Firebird V6 to LS1 swap</a><br /><b>V8 9.967@132.78</b> 1.322 60\' NA Heads/Cam<br /><b>V8 10.295@128.48</b> 1.363 60\' NA Cam Only<br /><b>V8 10.987@119.31</b> 1.422 60\' NA Stock Internals<br /><b>V6 13.674@98.22</b> NA<br /><b>V6 12.394@104.91</b> N20 100HP
Another list tells me DTC P1676 Driver 4 Line 6.
WTF does that mean? lolKeith - Chicago<br /><a href=\"http://www.hptuners.com\" target=\"_blank\">HP Tuners - PCM Reprogramming</a><br /><a href=\"http://www.dxsoftware.com/magnus/\" target=\"_blank\">97 Firebird V6 to LS1 swap</a><br /><b>V8 9.967@132.78</b> 1.322 60\' NA Heads/Cam<br /><b>V8 10.295@128.48</b> 1.363 60\' NA Cam Only<br /><b>V8 10.987@119.31</b> 1.422 60\' NA Stock Internals<br /><b>V6 13.674@98.22</b> NA<br /><b>V6 12.394@104.91</b> N20 100HP
ok.. lets see..
P1676
p=powertrain
1= a GM code (not govt' mandated requierment or sae)
6= computer and output signals
Sounds right, that audi list is correct, i found the same code in alot of those places..
Now all we need to do is figure out the component number 67 in the computer group..
:rolleyes:
and yeah.. thats all i got..
Totaly agree w/ magnus its the "Driver 4 Line 6"..
I have no idea what that means, lets do some data mining shall we?
well here
" 71-65-66 NOV 97 Engine Controls - EVAP DTC's P1665 & P1676 Added "
that is from alldata as a TSB i dont know what "EVAP" is though..
http://www.alldata.com/TSB/43/984343FD.html
ahh.. HA! evap..
here is more on EVAP
"EVAP
Evaporative emissions from the fuel system (fuel vapors) are trapped and store in a charcoal canister. Later, a purge valve opens allowing the vapors to be sucked into the engine and reburned. The EVAP system usually requires no maintenance. The fuel filler cap is also part of the EVAP system, and is designed to keep fuel vapors from escaping into the atmosphere. A leaky or missing fuel filler cap may cause a vehicle to fail an emissions test."
I think it would be wise to check the canister.. Haynes manual will go a long way with testing that system..
or it could also mean
P1676 ODMD Output 6 Circuit Fault
I dont really now the answer to this..
but hopefully this was helpfull..
good luck
~Bill
Went to the dealership and had a friend look it up. It is indeed the evap cannister system, since my car doesn't have one. [img]smile.gif[/img] So all I'm getting is the evap, the rear O2, and the EGR. So Once I get those turned off, and the shift/gearing tables corrected for 3.73's I'll be ok I think. [img]smile.gif[/img]Kelly \'GhoSSt\' Rosato<br />1996 Impala SS, 385ci LT4, 52mm TB, Quad1 headers, !Cats, !EGR, !AIR, Hooker Catback, SLP TC, UK3, UL0, GM CD changer, Onstar®, Homelink® Remote, lots of Fleetwood, Denali & 9C1 Stuff.<br />1998 Z28 Convertable (stock at the moment)<br />1993 Caprice 9C1, 406ci MPFI, overhead console, 8-way Riviera seats, DVD, CD Changer, etc..<br />1977 Volvo w/ 3.8l V6 from a 1998 Firebird
driver 4 probably refers to a particular driver chip (buffer) on the pcm. since each driver probably has a couple different programmable inputs/outputs, line 6 probably refers to the particular i/o line on the chip. it probably just a handy way to individually identify each of the i/o lines for purpose of the dtc message. of course, other years might reuse this line for other things but its unlikely -- this could lead to confusion about the error code. the line was probably unused since driver chips usually have 8 or more i/o lines. i suspect the pcm designers put quite a few extra lines on the board to allow for this type of expansion. it would expensive to respin the pcm just to add an i/o line.
the evap canister probably has a vacuum sensor on it that says "i do not see vacuum -- oh no the evil gasoline vapors are getting out another way"
