fuel lines, 98 vs 99+ - FirebirdV6.com/CamaroV6.com Message Board
  • fuel lines, 98 vs 99+
    Hoping to get some info from you guys.
    I have this part number, 10424769 they are OEM fuel lines, and i belive they are for the 99+ v6, can anybody confirm this.
    And if so, can somebody get me the part number for the 98 V6, as well as a pic of the top of the fuel tank assembly.
    ... reason i want to go to a return style fuel system, using OEM compontents, when i install my blower. The LS1 uses a weird setup, and is not easy to install a vac/boosty referenced regulator.
    The part number i posted came with the incon TT kits... so i know the lines will support the 500 hp goal i have. I belive the 98 lines should as well.
    Thanks
    Ryan
    1998 Ws6 Ta M6 #370 Bright Red<br />Custom \"NX\" style switch panels $35<br />Plug in fan switches $50 <br />SLP lid, Pro 5.0, Corsa, Custom Fan switch<br />....vortech waiting to be installed.
    10424769 is used on 98s and 99+ V6s.
    Matt
    1998 Mystic Teal Camaro M5
      5 days ago
