I bought a 1993 chevy camaro with a 3.4L v6 matted to a manual 5 speed. I want to know if i can put a 1986 pontiac trans am 350ci into my car? the Trans am's engine is good but the car is crap. the Trans Am cost $550. Is it possible to swap this 350 engine into my car? If so what all do i need to do? What will the costs be? we are planning on doing the swap by ourselves. I would like to keep my 5 speed transmission
[ July 23, 2002: Message edited by: cwh_2002 ]</p>
Possible most likely. I forget if there is clearance issues if it has a rear distributor or not. You will need the tranny, wiring, computer, new motor mounts, radiator and fans.
1. Welcome to the board [img]graemlins/thumbsup.gif[/img]
2. The 94 3.4 I'm swaping in was replaced by former owner w/454. your 350 should fit, but you probly wont be able to see the distributor.
3. everything zlightning said plus: springs/struts, and registration in non e-check county if applicable.
2013 Ram 1500 Big Horn
94 comero 3.4
3 days ago
