Need Advice About What to Do - FirebirdV6.com/CamaroV6.com Message Board
  • Need Advice About What to Do
    I'm thinking about either buying a 2001+ engine and transmission if I can find one cheap enough over the summer, or rebuilding my entire valvetrain on my current 97 engine, as in doing all of the following things:
    Comp Cams Valvespring Retainers
    Crower Chromemoly Retainers
    GM Factory Replacement Valve Locks
    SLP Aluminum Roller Rockers and Pushrods
    Comp Cams High Energy Lifters
    GM Factory Replacement Fuel Injectors
    Total comes to around the price of a new engine installed, but two things I'm debating. One is that I know this setup will be a whole lot stronger and better than a newer stock setup. However, I don't know if it would be better to do this and keep the stock internals or buy a newer engine with less miles on the internals and a weaker stock valvetrain. Any advice as to whether or not I should get a new engine or rebuild the topend and lifters and fuel delivery of the one I have now? (I have 95000 miles on it and race it from time to time)
    C. Boney<br />1997 Firebird 3.8L V6<br />---------------------<br />Modifications:<br /> <br /> SLP Cold Air Induction, Ported/Polished Throttle Body, Carsound 3\" High Flow Cat, Sweet Thunder 24\" Chambered Muffler, Removed Rear Exhaust Section, Custom Fan Switch, 35th Anniv. Silver Stripes, Old T/A-Style Silver Sail Birds
    ohh man rebuild rebuild rebuild =D
    97 Special Edition Bird , Short bus stlye special
      I would rebuild it...
      2002 5-spd NBM Camaro
      Details: www.1lev6.com
