FInished My do it yourself head porting - FirebirdV6.com/CamaroV6.com Message Board
  • #16
    <blockquote>quote:</font><hr>Originally posted by slacker69:
    Dee what did you do to your rocker arms. Im curious <hr></blockquote>
    Nothing, I just took a pic comparing the 1.9:1 to the stock rocker(1.6:1). ;)
    It is alot of work isn't it? hehe..... I wouldn't port a set for less than 600 for that amount of work.
    DEE
    1997 GTP(13.3@104)-Sold<br />1999 Trans Am M6
    • #17
      Your no kidding man i thought i was getting ripped off by getting my heads ported. But man it takes like 20 hours a head. WOW.
      • #18
        Here is a pic of one of the combustion chambers polished up. tell what yall think.
        http://www.mymilkexpired.com/tempstor/onecylinder.jpg
        • #19
          <hr></blockquote>
          Looks good. I have read many different views on that. Some say it doesn't matter and is only cosmetic and alot of shops do it because that is what the customer is expecting. Some say it will decrease carbon build up and reduce detonation. I didn't have a mirror shine on mine, but I did polish it up. Just avoid taking out too much as every little bit you remove lowers your compression.
          DEE
          [ March 13, 2003: Message edited by: DEE97GTP ]</p>
          • #20
            Thanks for the advice.
            • #21
              http://www.mymilkexpired.com/tempsto...ionchamber.jpg
              http://www.mymilkexpired.com/tempstor/exshuastport.jpg
              http://www.mymilkexpired.com/tempstor/Intakeport.jpg
              • #22
                that looks nice Kris!!! \m/
                :eek:
                • #23
                  Just to let you know porting is finished just need to get a valve job and little things milled and the deck milled down .02
                  • #24
                    looks VERY nice...
                    i'm doing my intake manifolds right now with some dremel supplies and good ol' sand paper.
                    my lower into the heads looks GOOD...combustion chambers look SWEET man.
                    what all have you used?
                    2011 Camaro LS 6M, in black.
                    • #25
                      The dremel bits i used are:
                      http://www.dremel.com/productdisplay...2&color=009933
                      http://www.dremel.com/productdisplay...3&color=660099
                      Those are the most important. The extension tool is really good to use.
                      http://www.dremel.com/html/products/...andpieces.html
                      • #26
                        i don't really care too much for the 932, as i had some problems with keeping that one even...but i do faithfully employ the others. Very nice job they do.
                        gonna use some buffing wheels too, see what i can do with those.
                        i ported out and am polishing the lower where it meets the heads. i'm pretty much just removing the rough casting and polishing up the lower where it meets the upper.
                        the upper is gonna get a good working over though [img]smile.gif[/img]
                        • #27
                          how do you decide how much to sand down?
                          • #28
                            What does port and polishing heads do?
                            • #29
                              <blockquote>quote:</font><hr>Originally posted by MrCoffee:
                              how do you decide how much to sand down?<hr></blockquote>
                              you talkin to me? if so...
                              i pretty much took the intake manifold gasket and ported it to that size. there was a decent amount of meat to work with there...
                              i dunno what i'm gonna do to the upper manifold...that's gonna be a LOT of work
                              • #30
                                Yeah i gasket matched and then in the bowl and pocket area i pretty much just took the casting off and made it a smooth area.
