Vacuum in the radiator hose - FirebirdV6.com/CamaroV6.com Message Board
  • Vacuum in the radiator hose
    Anyone ever experience this? I'm stumped on this one.
    I thought my hoses were worn out because they had colapsed. The car would stay in the 220 range with lack of coolant flow from the restriction. So I replaced the hoses, took the car out and the next day I open the hood and the upper hose is totally flat. When I opened up the bleeder valve it sucked air in and expanded the upper hose back into place.
    This can't be normal.
    Michael Huff<br />92 RS, 98 V6, 97 SS, 00 Z28 <br /> <a href=\"http://www.carolinafbodyclub.com/\" target=\"_blank\">http://www.carolinafbodyclub.com/</a>
    Miiike Miike this is your engine .. . bleeeeeeed me ... Maybe your thermostat is frozed / stuck shut?
    -Rob
      LOL, that's the general consensus I'm getting from the ppl I've been chatting with.
      I just rememberd the Hypercheese 160 thermo was my first mod about 5 years ago, guess it might be worn out. ;)
        If its sucking down flat perhaps you need a new hose or more coolant in the system? The system should be pressurized, not under vacuum!! thats pretty funny though [img]smile.gif[/img]
        2002 5-spd NBM Camaro
        Details: www.1lev6.com
          Wow, vacuum is odd.
          I'd say it has to be either thermostat or radiator cap.
            I just put new hoses on the car, I thought that was the problem. Then on the first run it sucked the top one flat again. I ordered a new thermo, will replace that and then see what happens.
