I was playing with desktop dyno, which has been giving me surprisingly accurate results.
My comp 200/206 cam is ground with 4 degrees of advance. As far as I can tell, this is hindering the potential of the cam. If I retard the cam back to 0 degrees, it will produce about 20 more hp. If I retard it 4 degrees, It will produce 40 more total hp. If I retard it more that 4 degrees, performance starts going down again.
Normally, if you retard a cam, you will gain power in the upper rpm range, and sacrifice power down low. When you advance a cam, you will get more low end power at the expense of upper rpm power.
My simulation showed that by retarding the cam a few degrees, I can increase power across the board without sacrificing low end power.
I am concerned about valve/piston clearance, but I can check that when I am putting the engine together.
Will retarding my camshaft have any adverse effects on daily drivability? Has anyone ever done this before?
