Gauge problems - FirebirdV6.com/CamaroV6.com Message Board
Gauge problems
This topic is closed.
  • Gauge problems
    My speedadamer is hoping around when bass is on low but since then my gauge move alot like oil and battery do you think the bass messed my gauges up ?
    No but your stereo is drawing too much power from the rest of things -- leaving not enough to power the gauges. They're the first to go / show when things are draining heavily.
    This belongs in the Stereo forum, but I can tell you that it's either a battery or alternator problem, or a 3rd fix would be to lose the stereo.
      WTF...
      1)this probably belongs in the audio/electronics section..
      2)I dont understand exactly what is going on.. you need to give mor details.. which guages.. what are they doing.. and when..
      more thinking owns you..
        [img]graemlins/twak.gif[/img] gawd dammit.. let me haze the newbie.. its my turn..
          my speedatomer hops like 5mph higher with stereo on my lihgt also dim with the bass preety high and if i dont use my car for 2 days my radar drains my battery it only 12 volt do u think it my battery ?
            Why don't you read what he typed..he has all the answers to your questions in the first post..
            which guages..
            Speedometer, oil and battery guage
            'hoping' around...irratically moving.
            and when..
            when the bass is on low.
            94 Camaro 3.4 A4 <br />T-Tops<br />In the process of an LS1 swap.
              This is definatley not advanced tech.. I'm moving it to general.
              Keith - Chicago<br /><a href=\"http://www.hptuners.com\" target=\"_blank\">HP Tuners - PCM Reprogramming</a><br /><a href=\"http://www.dxsoftware.com/magnus/\" target=\"_blank\">97 Firebird V6 to LS1 swap</a><br /><b>V8 9.967@132.78</b> 1.322 60\' NA Heads/Cam<br /><b>V8 10.295@128.48</b> 1.363 60\' NA Cam Only<br /><b>V8 10.987@119.31</b> 1.422 60\' NA Stock Internals<br /><b>V6 13.674@98.22</b> NA<br /><b>V6 12.394@104.91</b> N20 100HP
