Three trouble codes WTF - FirebirdV6.com/CamaroV6.com Message Board
  • Three trouble codes WTF
    Okay, I took my car to autozone to get it scanned since I know I have P0420 because of a severe lack of a cat [img]graemlins/rock.gif[/img] . they pull 3 more codes and they are as follows:
    P0137 - O2 Sensor Circuit Low Volts (Bank1 Sensor2)
    P0138 - O2 Sensor Circuit High Volts (Bank1 Sensor 2)
    P0140 - 02 Sensor CKT No Activity (on you guessed it) Bank1 sensor 2.
    bank 1 sensor 2 is the o2 sensor behind the cat correct? also. why would the computer double the codes? i had 8 listed P0420,P0137,138,140 X 2 wtf is up with that?
    00 Camaro with the Y87 Package!<br /><br />stock times 15.59 @86.3mph with a 2.25 60\'
    yeah.. i am 90% sure thats the post cat sensor.. sounds like its not hooked up.. are u running a SIM??
      the computer will sometimes set redundent codes.. i dont kno why.. but it does that when i scan mine with auto tap also.. its probably to show that it wasent jsut a ONE time issue..
      what i dont undersand is how you could set the low and the high votage code..
        i'm not running an o2 sim. i have true duals tho
          thats probably it..
          you probably jacked up the psot cat o2 sensor..
          i really dont know how that setup would be with "true duals"
          since you need 2 cats.. or no cats.. and well.. you only have one post cat 02 sensor.. so.. 1/2 of your exhaust is not getting metered.. i dunno.. you gota either get a sim.. or work something else out..
            You need a SIM.. I've got one and guess what... No codes.... [img]tongue.gif[/img]
            2000 Firebird. Whisper Lid, True duals, TSP mail order tune, Built Tranny , TCI 2800 stall verter, B&M tranny cooler, Eaton LSD, 3.42 gears. Current best ET. 15.232 89.09 MPH 2.175 60ft on stock 3.42\'s and open diff.<a href=\"http://www.geocities.c
              which sim do you have timbo..
              all the ones i have never ****ing work.. they give me error codes..
                but what gets me is the fact that it gave 3 codes that contradict each other. thats whats bugging me
                iknew the o2 was dead.
                  I got it at a V8 shop. It's the same one LS-1's use, they're sold in pairs.
