i was thinking of getting a 00 pcm i just called hypertech and talked to someone who works there and he said if it is a4 or m5 it will work i just wonder because some guys in the forum said it will not work i have a 99 bird and if it does work when i order it should i get a 00 pcm or y87 or they the same any info will help
pcm a4 or m5
your posts dont make much sense... but i think one of your questions is if your car will work with a 00 PCM and the answer to that is yes. will HPP3 work on that? in theory it should. i have my 99 programmed with an 00 vin but have not tired an HPP3.
<blockquote>quote:</font><hr>he said if it is a4 or m5 it will work <hr></blockquote>
what other options are there? if your car is an A4 then you will need an A4 programmed PCM
what gears do you have?
if you have 3.42s and an A4 then you will want one programmed for that like the Y87 PCM is.
[ March 18, 2003: Message edited by: hawgs ]</p>
i know a guy at a local pontiac dealership... gave him the 00 vin from kris' (slacker69) car and he did his thing.
if you are gonna go with 3.73s then it doesnt matter what the PCM is programmed for, as long as it is from an 00-02, because you will have to reprogram it with the HPP3 for the 3.73s anyways.
