Well there are alot of dremel bits out there that make head porting pretty easy. Things to remember are:
1. Less is more dont take out to much.
2. Dont change the physical geomotry of the heads.
3. Dont touch the valve seats.
4. You have to get a valve job when u are done.
<b><a href=\"http://www.sick-sixx.com\" target=\"_blank\">SICK-SIXX MEMBER</a></b><br />NA 14.345 with a 1.863 60 foot<br />Nitrous 13.03@99.5 with a 1.63 60 foot<br /><br />2000 Camaro 3.8L A4: USE TO HAVE Comp Cam 210/220 .535/.547 113lsa 111 I/C, Port and Polished Heads, NX Wet Kit 100 Shot, CPRA made by CP, RK Sport Headers
Not to be stupid but what exactly happens when you do a valve job?
\'94 Pontiac Firebird 3.4<p>MODS<br />Custom CAI, by pass cat,<p>soon to come<br />SLP CAI, sweet thunder exhaust, 1.25 lowering springs, 3 pt sub frame connectors, traction bar, port & polished heads & intake manifold, Headers, strut tower bar, ram air hood, SLP rims 18 in, tires? any suggestions? E-mail at firebird1206@aol.com
If I'm not mistakn a valve job is where the machine shop recuts where the valve "seats" against the head to make them fully close when they should. They have to close and "seal" good for your car to run correctly.
3 days ago
