Hey guys, I'd rather post this in Adv tech where someone w/ the knowledge might actually see it and help me out here. I'm growing a little tired of this problem. Long story short my stock pump stopped working, it wasn't cycling through so I replaced it with a walboro 255. I'm not using a bucket for a few reasons while I know I should however that is not the issue here. I used the supplied wire adapters to hook up the pump to the harness, I also triple checked everything before I put it in, all the connections are made. Everything looks good. I put it in connect the lines back up from the top and tighten it down. The fuel filter is replaced, and I got a new relay in. However, when I go to turn my ignition and let it sit, I can't hear the fuel pump cycle through, my old one wasn't doing it either when I replaced it. What the hell is going on here. It looks like it's not low on voltage. I don't get it. Please help!!!
Need help bad with a new fuel pump not cycling.
As in you cannot hear it priming the system when you turn the key forward? Have you put a volt-meter on the wires back at the pump to see if they are getting fire? If so, what are the voltages at each step (ie: key forward, running, etc)? Also have you put a pressure gauge on the fuel rail to see what your pressure looks like?<a href=\"http://www.fullthrottlev6.com\" target=\"_blank\">www.fullthrottlev6.com</a> THE SOURCE!
Ok I got the problem solved. I checked every fuse in the system, I looked over everything for like 30min. And I figured it has to be something PCM related because thats whats controlling it. I checked the PCM Batt Fuse, nothing, so I checked the PCM/IGN fuse again and it wasn't blown but the backside looked kinda fuzzy on the fuse part. So I replaced it and it cycled right through. It would suck if that was my problem all along, but I guess i'll never know, lol. Fuel pump works great, car runs nice. I'm running it w/o the bucket btw.
Glad you got it worked out!
Thanks for posting what you went through to fix the problem too.\'98 A4 Camaro v6->v8 conversion, and STS kit next<br />v6: 13.6 Powerdyne, 13.2 150 shot, 13.8 120 shot, 14.3 85 shot, 15.7 stock<br />v8(na): 12.18@113, 392rwhp<br />Moderator on <a href=\"http://www.mtfba.org\" target=\"_blank\">www.mtfba.org</a> and <a href=\"http://www.frrax.com\" target=\"_blank\">www.frrax.com</a> (Road Race & Autocross)<br /><a href=\"http://community.webshots.com/user/johnduncan10\" target=\"_blank\">Car pics</a>, <a href=\"http://www.trscca.com\" target=\"_blank\">TN Region SCCA</a>
