I just intalled a cam and everything was running fine for about a week. Now when i accelerate, Its fine but when I hold it at any speen, It has a slight hesitation to it. anyone experienced this before???
hesitation at steady throttle
96 3.8 red camaro. <br />headers,cam,valve springs,retainers,auburn lsd,3.73 gears,SLP cold air,accel coils,24lb injectors,8mm plug wires,air temp module,LT1 diveshaft,removed a/c,edelbrock torque arm,spohn LCA\'s and PHRTags: None
acceleration is fine, stronger than ever. but when I am driving at a constant speed, it rides rough, kinda like sputtering. I dont know what it is. The fuel filter is brand new, the injectors are clean and all read the required voltage, none of the plug wires are arcing, the coils are all good, all the plugs are new and the air filter is clean. I have zero vacuum leaks because it would accelerate rough too and the timing is right on. I can't think of anything else that would cause it to act like this maybe my throttle linkage but thats kinda a little far fetched.96 3.8 red camaro. <br />headers,cam,valve springs,retainers,auburn lsd,3.73 gears,SLP cold air,accel coils,24lb injectors,8mm plug wires,air temp module,LT1 diveshaft,removed a/c,edelbrock torque arm,spohn LCA\'s and PHR
I think you mean its surging. This can happen with cammed cars, when the computer doesn't like it? What cam are you running?Turbocharged and intercooled.<br />17psi(oops), stock fuel pump, no FMU<br /> <a href=\"http://www.cardomain.com/id/phoenix64\" target=\"_blank\">http://www.cardomain.com/id/phoenix64</a> <br />Video: <a href=\"ftp://ftp.pfabrication.com\" target=\"_blank\">ftp://ftp.pfabrication.com</a> Assorted car ****: TurboCamaroFull.
its a blower cam. 212 220 512 512@ 115. And probably, I was cursed with the gift of not being able to explain things well.96 3.8 red camaro. <br />headers,cam,valve springs,retainers,auburn lsd,3.73 gears,SLP cold air,accel coils,24lb injectors,8mm plug wires,air temp module,LT1 diveshaft,removed a/c,edelbrock torque arm,spohn LCA\'s and PHR
this may not be helpful but ive heard you have to get a special type of cam for computer controlled vehicles such as the 82 and up camaros. Powermax offers computer controlled engine cams for 169.99 if you have to change it out.Proving that import racers aint got **** on Domestic Muscle. Long live the CAMARO!<br />Soon to come- Powermax Cam/ Crane Lifters
need help finding a balancer and a replacement balancer bolt. im at a lost after confusing myself researching.5 hours ago
Hello every one, ozzy here ive been looking at this page for weeks now finally joined. So my question is why is it that every turbo build forum just ends...2 days ago
by 2.8 BirdI wish you guys the best for you and your family. Good health, happiness and prosperity. Merry Christmas and a happy new year....1 week ago
