All the local shops are scared to death of the l36 to ls1 swap. Many say they won't attempt it,alot say that they would do it for about 15k worry free,and others say maybe 10k if I supply the engine. If I pulled one of those 3k engine/tranny combos off of ebay how much would the other stuff cost? Then I'll go from there. I know this has been discussed but it does good to add to the search database.
LS1 swap @ $15k!!
LS1 swap @ $15k!!
<a href=\"http://www.cardomain.com/id/camazoic\" target=\"_blank\">http://www.cardomain.com/id/camazoic</a><br /><br />Interest:Sports,Cars,Sport Cars,Sports with Cars in them, and using my Car to Sport(obselete meaning) in.Tags: None
For 15k you might as well buy a low milage Z28 or TA<a href=\"http://www.cardomain.com/id/camazoic\" target=\"_blank\">http://www.cardomain.com/id/camazoic</a><br /><br />Interest:Sports,Cars,Sport Cars,Sports with Cars in them, and using my Car to Sport(obselete meaning) in.
15K is stupid expensive.
you should be able to do it for $2000 plus parts from a good shop.
Ryan1998 Ws6 Ta M6 #370 Bright Red<br />Custom \"NX\" style switch panels $35<br />Plug in fan switches $50 <br />SLP lid, Pro 5.0, Corsa, Custom Fan switch<br />....vortech waiting to be installed.
throw tiagos turbo on it, save thousands and kill v8s with a v6. keep mileage and have narly bragging rights. nice car though man...good work96 Camaro 3.8 A4 Basemodel: 8 mm wires, Shift Kit, Hollowed <br />Cat(o2 sims), RKSport exhaust, IAT 5.6K resistor, Home Depot CAI<br />>>>15.375 @ 89.27<<<NEW BEST TIME <a href=\"http://www.cardomain.com/memberpage/552491\" target=\"_blank\">http://www.cardomain.com/memberpage/552491</a>
the shops around here would do it for $1200, but, you prolly will need the V8 suspension, fuel pump, radiator, rear end gears (if the v8 you get comes with an auto trans because if the gears dont match the computer will get confused) ect..
i agree with Die Ford... Tiago's kit would be my choice. Much more original also, well kind of.\'94 Firebird, 3.4 M5.<br />Arctic white w/ red anniversary stripe. ASP underdrive pulley set, Magnaflow 2.5\" stainless catback, CAT, Pacesetters, K&N FIPK2, 1000 watt stereo system capped 1F, Eagle Alloys 16\" 077\'s, 180 Deg. Thermo.
yeah engine swap should be no more than 2k, and you provide engine
Hey Brandon, not to get off topic but how much was the paint job since you went from NBM to yellow?
Thanks
Brandon2000 Black T/A M6 343rwhp 349rwtq<br />11.94 @ 118 60\'1.79 Stock Internal<br /><a href=\"http://www.cardomain.com/id/demonicbird00\" target=\"_blank\">http://www.cardomain.com/id/demonicbird00</a> <br />AIM: W68Firebird97<br />R.I.P... Christine 12/25/02 <br />1997 Firebird W68 Black<br />14.887 @ 90.08
Thanks
Brandon99\' Camaro v6 T5- SOLD<br />2004 VW Golf TDI
i think the shop is scared and threw u a high price to make you run from the idea
