Oil pressure probs. need advise - FirebirdV6.com/CamaroV6.com Message Board
  • Oil pressure probs. need advise
    ok when i first crank up my car after it has been sitting everything is fine but after like maybe 20 minutes of driving my oil pressure fluctuates with my throttle majorly and if i stop or just idle it will die down low and even at some times set off the check gauges light but the car runs perfect i have been driving with it like this for i while(not a good idea i know but i have no chioce) i changed oil and filter cause it was a very old filter and i thought it got better but i was wrong
    anyone???
    1998 Jet Black Trans-am M6 T-tops<br />\"Ask, and it shall be given you; seek, and ye shall find: knock and it shall be opened unto you:-Matthew 7:7<br />Old car<br /><a href=\"http://matthew27529.tripod.com/getsome\" target=\"_blank\">http://matthew27529.tripod.com/getsome</a><br />NEW CAR<br /><a href=\"http://garnerebel.tripod.com/\" target=\"_blank\">http://garnerebel.tripod.com/</a>
    another oiling problem? :eek:
    in this case, I would suggest replacing the sending unit. could be as simple as that. whenthe car shuts off, that's when you have bigger problems ;) :(
    [ August 01, 2002: Message edited by: 3.4 slow to go ]</p>
    2013 Ram 1500 Big Horn
    94 comero 3.4
      i was thinking that when i put on my headers i hit the oil sending unit and broke it so i bought a new one and put it in maybe it was a bad one :mad: i will try this tom.
        Sending unit maybe. Have you tried some Lucas Oil Stabilizer? I know it's not a sulution to the problem, but it can be a supplement to your sulution. It helped my oil pressure come up and stay up even at idle.
          sounds like the oil sending unit
