Can you rev your engine past 4500rpm when not in gear? - FirebirdV6.com/CamaroV6.com Message Board
  • Can you rev your engine past 4500rpm when not in gear?
    I know, it isn't good to do, but Iwas revving the engine to listen for some problems i had been having, when I noticed at 4500rpm, it dies and drops to idle. Kinda like fuel starvation, is this supposed to happen? Asafety to keep idiots like myself from blowing the engine, or is there a real problem here? I just replaced plugs, pcv, fuel filter, and changed the oil, so everything should be good. This car is starting to worry me...maybe it's too smart for its own good!
    thanks
    If you have an automatic this is normal. Rev limiter is dropped to 4500 RPM when your in neutral. The rev limiter is just a fuel cut-off at a certain RPM.
    If you keep on the gas you'll notice the tach needle kinda bounces when you get to 4500 RPM = what they call "bouncing off the rev limiter". Just stating this for newbies' future reference ;)
    ~Derrick <a href=\"http://www.appstate.edu/~do54457/\" target=\"_blank\"><i>My Webpage</i></a><br /><b>\'96 3.8L V6 M5 Firebird Y87</b> | <b>162.8 RWHP</b> / <b>196.7 RWTQ</b> <br /><b>•</b> SLP CAI <b>•</b> <a href=\"http://tech.firebirdv6.com/y87.html\" target=\"_blank\"><b>Y87</b> Package</a> - 3.23s <b>•</b> 180º thermo w/ fan switch <b>•</b> TB spacer from DEE<br />1991 Jeep Cherokee Laredo 4x4
      as Dojo said, its a rev limiter
      Its much lower in neutral than in gear because its a lot easier for an engine to tear itself apart when revving high w/ no load.
      In gear, the rev limited is 5400-5600, though it may look like you go past that on the tach.
      2001 75th Anniversary V6 Pewter Firebird w/ Chrome Wheels, T-Tops, & Y87<br />Mods: Free Ram Air, !Silencer, Holley Filter, Full 3\" Hooker Catback, 3\" Cat<br />Best time: 15.095 at 90.00 MPH with a 2.127 60\'
        Hmm mined goes to 5500 at least out of gear i have never dared to try more
        My new ride 2000 camaro, No mods yet still waiting for warranty to run out then all out heads, cam, and supercharger
          Thanks for the clarification there, but i have a manual tranny...any difference?
          thanks
            <blockquote>quote:</font><hr>Originally posted by predator5100:
            Hmm mined goes to 5500 at least out of gear i have never dared to try more<hr></blockquote>
            you have a 3.4. Everyone else that posted has the 3.8 [img]smile.gif[/img]
              <blockquote>quote:</font><hr>Originally posted by blackfire99:
              thanks
              <hr></blockquote>
              As far as I know the PCM never even knows what gear your in with a manual (reverse just hits a switch the turns on your back-up lights), so no decreased rev limiter
                So in this case, sould I be able to rev past this point? This is really a pain not knowing anything for certain...
                thanks
                  i have a 3.4 5 speed and my car dies right after 4500rpm i hate that but i still take it to 5500
                  any suggestions on how to feel power all the way
                    <blockquote>quote:</font><hr>Originally posted by Jlo:
                    <hr></blockquote>
                    We're talking about when your sitting in you're drive way reving your engine in neutral. I think your talking about when you're actually accelerating on the road.
                      Summary: Rev limiter is only on AUTOMATICS! Limiter seems to only be on the 3800 engine also. So, if your call is not an automatic 3800, then you may not have one. (all in a nut shell, at least thats a summary of what everyone said)
                      95 quasar blue 3800.<br />K&N, blackout tint,<br />Headlight and tailight blackouts<br />300 watt 10\'s <br />$400 polk highs and mids<br />pioneer DEH-P6300 HU<br />chrome 5 star 15\" rims
                        <blockquote>quote:</font><hr>Originally posted by Fat_kid_in_little_camaro:
                        Summary: Rev limiter is only on AUTOMATICS! Limiter seems to only be on the 3800 engine also. So, if your call is not an automatic 3800, then you may not have one. (all in a nut shell, at least thats a summary of what everyone said)<hr></blockquote>
                        No, no, no. All 3.8s have a rev limiter! The rev limiter is ~5600RPM. If you have an automatic your rev limiter is dropped to ~4500RPM by the PCM only when you put the transmission into neutral
                        If you had no rev limiter at all you would be able to rev to redline and beyond, in most cases causing internal engine damage.
