I was wondering if i can go from stock in jectors to 26 lb/hr injectors? Would this require any changes to the ecm/pcm?????
3.4 L v-6 injectors
not really sure why you would want to go that high it is not really needed unless your planning on some major mods. i know tiago is running 24lbs with no computer tunning just a afpr.i will be running 19 untill i get the ummm boost factor then i will go up ;)1998 Jet Black Trans-am M6 T-tops<br />\"Ask, and it shall be given you; seek, and ye shall find: knock and it shall be opened unto you:-Matthew 7:7<br />Old car<br /><a href=\"http://matthew27529.tripod.com/getsome\" target=\"_blank\">http://matthew27529.tripod.com/getsome</a><br />NEW CAR<br /><a href=\"http://garnerebel.tripod.com/\" target=\"_blank\">http://garnerebel.tripod.com/</a>
<blockquote>quote:</font><hr>Originally posted by southern94:
not really sure why you would want to go that high it is not really needed unless your planning on some major mods. i know tiago is running 24lbs with no computer tunning just a afpr.i will be running 19 untill i get the ummm boost factor then i will go up ;) <hr></blockquote>
whats a AFPR??
