There are a few people on here that have done one. Not sure how many still hang around. I pop in and look at advanced tech and forced induction every now and then...
If you get all new stuff, you're still going to need the accessories (alt, ps, water pump, a/c) and all the brackets. PCM, wiring harness. Radiator. Engine k-member. Tranny cross-member. Front springs. A donor car, or a complete pull-out, would be a lot simpler than trying to piece it together. You can always freshen up the ls1. Maybe even go heads and cam right off the bat with the money you save.
