SuperSix Sent Me......... - FirebirdV6.com/CamaroV6.com Message Board
  • SuperSix Sent Me.........
    ........here to find the answer to my question.
    I was talking to them about building me a complete race-prepped 3.8L since I've been looking for an engine replacement for some time now. Then I asked them about computer tuning, since I know there is basically nothing offered in that area for a '97 3.8L.
    They said "Magnus is the guy you want to talk to" So here I am. I'm Just wondering what can be done to the ECU to take full advantage of that setup.
    1997 Camaro,<br />SLP cold-air, Hooker Supercompetition catback, Air temp. module, Powerstat thermo, 1LE Aluminum drive shaft, 3.42 POSI rear, 1LE sway bars front & rear, Powerstop crossdrilled rotors on all corners, Torque Thrust II\'s (17x9.5 front & 17x11 rear), and a couple other goodies. <a href=\"http://www.villagephotos.com/pubbrowse.asp?selected=84487\" target=\"_blank\">http://www.villagephotos.com/pubbrowse.asp?selected=84487</a>
    Welcome to the board.
    http://www.3800performance.com
    They sell pistons that work with the L67 rods.. If your going all out thats probably the setup you'll go with.
    Those pistons can handle 18+ lbs of boost.
    As for tuning issues... I am working on programming of these PCM's however I cannot discuss it at the current time. I do minor reprogramming now but have not done cam reprogramming just yet..
    When I think of cam reprogramming, here are the basics:
    Increased desired idle (depending on agreesiveness)
    Increased rev limiter
    Inrease shift points
    You can also change the fuel curve to match the new VE of the engine, but thats a little more complex.. I won't go into that at the current time.
    Another things is timing advance.. but even a stock camm'd car could benafit from increased timing so this isn't a cam only adjustment. Same with top speed limiter.
    If your looking to fine tune the car, a MAF T+ is the best way, even if you do have programming. With a MAF T+ you can change the o2's at the track by .01 mv at a time and can also adjust timing based on weather conditions. You don't want to be pushing 31 degrees of timing in summer heat, just like you'd like a little more than 26 in the spring and fall cooler air.
    What are you looking to do with your engine/car?
    - Keith
      Hey Mag, did you have to do any kind of reprogramming to run the 24 pound injectors? Is stock 19 or 21?
        I did not touch the programming for the Accel 24 lb'ers.. the car actually runs near stock calibrations now with them and the cam.
