I talked to tom at super six today about getting their head treatment and he said they do the p&p, 3-angle valve job, and comp spring. I was originally going to do the full comp valve train package that AMM offers but not sure now, do you guys think its worth it or should I just stick with the comp springs that Super Six puts on.
super six heads
I was under the impression that Tom puts Comp 915 or 918 springs on the heads anyway. They are good for whatever camshaft selection you decide to throw at them. The only other things you need are hardened pushrods and of course your bolts and gaskets.<a href=\"http://www.fullthrottlev6.com\" target=\"_blank\">www.fullthrottlev6.com</a> THE SOURCE!
get the P&P heads from SSM and let him upgrade the springs for you, that way there already assembled and you dont have to mess with it. Use his heads with upgraded springs and keep stock rockers and upgrade the pushrods.
Originally posted by pgriffith:
get the P&P heads from SSM and let him upgrade the springs for you, that way there already assembled and you dont have to mess with it. Use his heads with upgraded springs and keep stock rockers and upgrade the pushrods.-Aaron, AKA ATL2001<br />93 3.4L <br /><a href=\"http://www.ilfba.com\" target=\"_blank\">www.ilfba.com</a>
Originally posted by StudlyCamaro: do you have his heads on your 3.4L or have you ever ridden in a 3.4L with his heads??? not trying to start anything , but if you havn't then you shouldnt tell someone that he does a good job... even if you have ridden in a car with his 3.8L heads its a completly different story.. [/QB]92 S10 3800 A4(96)<br />1/4: 14.374 @ 92.25 w/ 1.976 60\'<br />Turbo and 12\'s Coming Soon!
personally i think they are hella expensive seeing as ive never seen anyone's #'s after installing them
the 3.4L and 3.8L are compleetly different motors ... just because someone is talented at porting one type of heads dosent mean they have the experience and touch for another type of head... look at ,many local porting shops, they have guys that specalize in one, maybe 2 o3 types of heads ..
dont get me wrong im sure that they are better than the stock heads 100% , however i feel that until someone posts some ground breaking #'s with them you are better off going with a local shop to get your heads ported (then you dont have to worry about shipping them and the turn around will probably be faster)-Aaron, AKA ATL2001<br />93 3.4L <br /><a href=\"http://www.ilfba.com\" target=\"_blank\">www.ilfba.com</a>
I was assuming he was asking about 3.8 heads. My bad. I know tom does very good port and polish work. And has good customer service. I dont have experience with his 3.4 heads and i dont know if they flow as well as his 3.8 heads do. I do know he has great quality and workmanship on his 3.8 heads. I would assume he could get a pair of 3.4 heads to flow also.
by 187sharkHi all new to the community here. I have a 2014 RS 6 speed manual... and so about a year ago my tail lights got cracked and eventually the plastic housing...1 week ago
by ssms5411Still trying to find oil leak on my Camaro, it’s a tough one. I think it is the oil pressure sender myself. Leaking when raving and going into boost....3 weeks ago
