Originally posted by OreoLT1: Did they not put the Lt1 in 02 Z28's?
No, all 98+ f bodies had the ls1.
Also why is this in advance tech?
Since it's summer and you're in Florida, you aren't hurting ANYTHING by running 10-30 instead of 5-30. In fact, the same oil in 10w-30 may last a little longer before it breaks down in the heat. The cold weather protection provided by 5 weight oil is completely irrelevant for that climate at this time of year.
I run whatever is on sale for synthetic that meets GM 4718M [the corvette spec], Xw-30, at 5000 mile intervals w/ oversize filter.
\'00 f-bird 3.8 M5 coupe, pewter metallic<br />Torsen LSD, Pro 5.0 shifter, Spec stage 1 clutch, Y87 muffler, aftermarket stereo<br />-more fun than the Oldsmobile it replaced...
btw, the "regular" Royal Purple isn't the same thing as the #21, and there are several varieties of Amsoil, some better than others, and there are two varieties of Mobil 1, and 3 kinds of Castrol synthetic in the same range of grades... And group 3, 5, and ester based synthetics like Redline. It's really complicated.
To add insult to injury, many of the best oil analysis results lately on bobistheoilguy.com are actually coming from less expensive "dino" oils like Havoline, and not the synthetics.
3 days ago
