does anyone know how many bolts hold the lower intake on. what else do you have to remove to take the lower intake off.
lower intake bolt
lower intake bolt
2000 Firebird 3.8 A4 w/W68<br />WS6 Ram Air Hood<br />SSM Port/Polished Heads <br />NOS #05175<br />Accel wires<br />Accel Coil Packs<br />MSD DIS-4 High Output<br />zexel torsen w/3.42<br />SLP CAI<br />Whisper Lid<br />K&N filter<br />JET programmer<br />Hypertech 160 degres thermo<br />Flowmaster cat-back<br />air temperature module<br />Eibach Pro Kit lowering springs<br /><a href=\"http://www.angelfire.com/ar3/projectfalcon/homepage.html\" target=\"_blank\">www.angelfire.com/ar3/projectfalcon/homepage.html</a>Tags: None
Get a chiltons manual it will make your job 100 times easier. There are two hidden bolts on the intake one is in the passenger side front corner the other is on the drivers side rear.Longtubes, true duals, ram air, caspers tps tec, ls1 26lb injectors, supersix powerpack, heads milled .020, comp cam .507 220/224 114 ls, forged internals and chromeoly pushrods, bored .030 over, tb spacer, tranny built with stiffer springs and kevlar bands, bigger servo, transgo stage 3 shift kit, edge 3600 stall, 1 pc aluminum ds, 3.73 superior gears, lsd rear ,custom pcm tuning, walbro 255 in tank,
