Today I was driving home from my grandparents house and as I was braking, my check gauges light came on and I looked down, only to see that I had no oil pressure. I turned the car off, and popped the hood, everything looked okay, so I started it back up, and the oil pressure was all back, WTF happened? anyone ever have this happen before?
no oil pressure?
no oil pressure?
2002 A4 Pewter Firebird.<br />Aluminum interior, custom aluminum whisper lid, custom ram air, Flowmaster cat bacl, high flow cat, pacesetter headers<br />15.018 on a ****ty track<br />15.65 stock on same ****ty track<br />15.33 stock on good track<br />= 14\'s on good trackTags: None
The only time I see that is when an old 2.8 or 3.4 is about to die.
The hot oil and it sloshing to the frount, droping oil pressure from engine rpms slowing fast, cause it to drop fast.
I would take it in to the shop.
The pick up could have fallen out of its hole, seen that before.
You could have a dirty filter and stuck close bypass maybe.\'85 Z28, T-tops new LG4 and TH700<br />\'85 3.4L 5-speed<br />mods: <a href=\"http://www.cardomain.com/id/oil_pan_4\" target=\"_blank\">http://www.cardomain.com/id/oil_pan_4</a> the nitrous exhaust O2 safety, pg 3. <br />Areo space materal engineer wantabe
I know it didnt die, it had done it before on the dragstrip when I was slowing down, if it ever does it again, Ill just take it back to the dealer, but I dont think its a serious problem, probably the pick up2002 A4 Pewter Firebird.<br />Aluminum interior, custom aluminum whisper lid, custom ram air, Flowmaster cat bacl, high flow cat, pacesetter headers<br />15.018 on a ****ty track<br />15.65 stock on same ****ty track<br />15.33 stock on good track<br />= 14\'s on good track
my oil pressure light came on and i found out the wire going to the sender was broke so i have to fix it before i get my motor in1995 Camaro 3.4 M5 - Project<br />1998 Camaro 3.8 A4 - Daily<br />Aim:V6OnSpeed<br /> <a href=\"http://www.cardomain.com/memberpage/576233/1\" target=\"_blank\">http://www.cardomain.com/memberpage/576233/1</a>
mine has done that twice in the last 2 or 3 years, dont know what it is....once when i was racing a guy and i was running about 75-90, and the other time when i was slowing down after a pass at the track...i just did the same as you, get scared as hell, then fire it back up and the oil pressure came back...<b>Black</b> 1998 Pontiac <i>Firebird</i> A-4 swap<br />271.4rwhp/259.4rwtq NA<br />13.30@102.44 <br /><a href=\"http://www.freewebs.com/wickedsix98\" target=\"_blank\">www.freewebs.com/wickedsix98</a>
Been there done that, it was my oil sending unit. I've heard a lot of people who have had this problem. All of them that I know, including myself, just had a bad oil sending unit. It's cheap and easy to replace.Polo Metallic Green \'96 Camaro w/Y87 Performance Package<br /><a href=\"http://www.cardomain.com/id/greenmaro24\" target=\"_blank\">Corey\'s Camaro</a>
cool, thanks for everyones help, I'll get under there and see what I can do.2002 A4 Pewter Firebird.<br />Aluminum interior, custom aluminum whisper lid, custom ram air, Flowmaster cat bacl, high flow cat, pacesetter headers<br />15.018 on a ****ty track<br />15.65 stock on same ****ty track<br />15.33 stock on good track<br />= 14\'s on good track
