WHats the torque spec for head bolts on the 3.8? I forget?????????
TQ spec for head bolts?
They want you to do this in 3 steps and follow the torque sequence for each step. They want you to tighten each bolt a little bit at a time not all at once. I guess they could have said something like step 1 torque to 37 and step 2 torque on up 90 or whatever. I got this info from a haynes repair manual. Maybe someone else has a book that gives an exact number?2000 Camaro 3.8 v6 M5
Flowmaster 80 series muffler, B&M ripper shifter, SLP grille
<blockquote>quote:</font><hr>Originally posted by Andy H:
They want you to do this in 3 steps and follow the torque sequence for each step. They want you to tighten each bolt a little bit at a time not all at once. I guess they could have said something like step 1 torque to 37 and step 2 torque on up 90 or whatever. I got this info from a haynes repair manual. Maybe someone else has a book that gives an exact number?<hr></blockquote>
3 steps? 3 steps of what? Dude spell this out for me. Dont tell me my head gasket leaks because last time I tightend them 37 ft. pounds then 130 degrees and left it at that. Please spell this out for me.
ok
step 1. follow the sequence from the pic i posted and tighten all bolts to 37 foot lbs.
step 2. follow the sequence and tighten all bolts an additional 130 degrees.
step 3. follow the sequence and tighten center bolts 1-4 only an additional 30 degrees.
that's it. hope this helps [img]smile.gif[/img]2000 Camaro 3.8 v6 M5
ok
that's it. hope this helps [img]smile.gif[/img] <hr></blockquote>
Ok so center 4 bolts are an additional 160 degrees total between the two different steps right?
<blockquote>quote:</font><hr>Originally posted by pgriffith:
Andy your so much help thanks buddy, And what do I use to measure the degrees? Or do I just eyeball it?
Last time I eyeballed it and screwed up so maybe this time I should get a tool.<hr></blockquote>
Use a torque angle gauge, here is an example:
http://cgi.ebay.com/ws/eBayISAPI.dll...tem=2046121251
I eyeballed mine.. but a tool is recomended.Keith - Chicago<br /><a href=\"http://www.hptuners.com\" target=\"_blank\">HP Tuners - PCM Reprogramming</a><br /><a href=\"http://www.dxsoftware.com/magnus/\" target=\"_blank\">97 Firebird V6 to LS1 swap</a><br /><b>V8 9.967@132.78</b> 1.322 60\' NA Heads/Cam<br /><b>V8 10.295@128.48</b> 1.363 60\' NA Cam Only<br /><b>V8 10.987@119.31</b> 1.422 60\' NA Stock Internals<br /><b>V6 13.674@98.22</b> NA<br /><b>V6 12.394@104.91</b> N20 100HP
I would just eyeball it, im not sure where you would get a tool for it.<hr></blockquote>
Autozone, napa, should all have one. Only like $10 or so. Well worth it.
DEE1997 GTP(13.3@104)-Sold<br />1999 Trans Am M6
I have been told to retourqe them after the engine has been hot. Is this neccassary?<hr></blockquote>
That is nowhere in the manual. How much would you retorque them anyway? Being that you turned them a certain number of degrees. I think that is BS.
I never heard that on head bolts, but I know for instance if you are using rockers with non torque to yield bolts, that it is good to tighten them down one you get the engine warm. We do this on my friends racecar, a bit of a PITA.
FWI, I didn't, and it has stood up to 13psi and all.
