KR Question - FirebirdV6.com/CamaroV6.com Message Board
KR Question
  • KR Question
    Well I autotaped my car yesterday and I have about 4.1* of KR at WOT in 3rd gear. From what I read about false KR, it normally starts high, then goes down, and real KR starts low and goes high.
    I was studying my atap log and it started at 1.6* right about 5500RPM in second gear, then I shifted into 3rd and it jumped to 3.9* then to 4.1* then started going down again. I only took it to about 70MPH before I had to slow down. Do you guys think I have a real KR problem? I did a few runs, and the results were similar.
    If this is false KR, is there a way to get rid of it. I know I'm not loosing much power, but power loss is never good, and knock just isn't good for the engine either.
    BTW I just started running 93 octane again about 2 tanks ago.
    If it is real knock, higher octane should make it go away. Otherwise, it is likely to be false.
    Matt<br />2000 Firebird<br /><br /><a href=\"http://www.fullthrottlev6.com/forums/index.php?\" target=\"_blank\">FullThrottleV6.com</a>
      With your mods I would say it is false knock.
      2000 GTP<br />Thrasher CAI, 3.4\" pulley, DHP PCM<br />Member RedLineVSix<br />Best ET-14.02<br />Best Trap-97.15
        That's what I was thinking. What can I do to get rid of it? I've heard puting resistors on, but what kind and where?
          I have no idea what "resistor" thing you are talking about...sorry.
          As for fixing it, you will need to find the problem first. I would stay start with the exhaust and make sure nothing under the car is making contact with the body or frame.
            John's right - always try to isolate the source of the false knock instead of desensitizing the sensor. Much safer for the engine.
            -Jeff
            2001 Pewter Firebird Y87, M5
            Go Sabres!
              Put some high octane race gas in her first....then autotap...if no KR, it was real knock.
                does KR feel like a missfire?
                cause i just replaced my plugs and wires. i used ngk tr55's gapped .060, and taylor spiro pro wires, and it still feels like im mis fireing. so its either bad coil pack, or KR.
                it feels like a miss from 1k to 3k, then when it hits about 3.5k rpms it runs smooth again all that way to 6k.
                is that a misfire or knock retard. its its KR, how do i get rid of that?
                96 Camaro M5. Dark metallic gree (?dont know the offical color name)<br />Home made Intake :: Headers, 3inch headers back to Flowmaster muffler :: spec stage 3 clutch Now installed, waiting for 3.42\'s and LSD next month<br /><a href=\"http://photobucket.com/albums/y192/RiceEatingCamaro/?action=view&current=newcar.jpg\" target=\"_blank\">My Car</a> <br /><br />Totalled Car.<br /><a href=\"http://bellsouthpwp.net/s/k/sk8er305/\" target=\"_blank\">96 CamaroRS</a>
