Cam shift points - FirebirdV6.com/CamaroV6.com Message Board
Cam shift points
  • Cam shift points
    My car blew a headgasket, so both of them are getting replaced now. I figured while my friend's dad had the motor apart, why not throw in a cam.
    Here is what I bought from ZZP:
    ZZP GT 2 Cam
    The stock size Comp pushrods
    Comp valve locks
    Comp Titanium valve spring retainers
    LS6 Valve springs
    New timing chain
    new timing chain dampner
    new cam bolt
    My question is, when I get the car tuned how high should I set the WOT shift points and rev limiter? ZZP says 6500rpm WOT and 7k revlimiter, but I'm scared to do that on my block. The lower half will have 120,000 on it still (crank, pistons, block). ZZP also says 6200rpm with stock springs for WOT shifts, but I will have the LS6 springs.
    Still ok to rev it that high? If I can safely, I would love that. I love high revving motors.
    -1999 Camaro Coupe 3800 Series II V6 A4 - SOLD<br />-1998 Pontiac Grand Prix GTP coupe
    With a stock bottom end I wouldn't want to let it wing up to 7k. Maybe set the rev limiter at 6700 or 6800 and set shift points at 6300 or 6400.
    Anyone else have a better idea of what these things can handle?
    - Justin
    <a href=\"http://www.njfboa.org\" target=\"_blank\">New Jersey F-Body Owners Association</a><br />1987 Camaro LT - 400sbc, Aluminum L98\'s w/valve job, Comp XE 274, Q-Junk 750, 3.23 posi, 4.10\'s soon.<br /><br /><a href=\"http://www.njfboa.org/forums/viewforum.php?f=11\" target=\"_blank\">East Coast F-Body Nationals - August 14, 2005</a>
      Sounds like another dyno day will be in order soon.
      What are you using for tuning?
      01 Camaro A4 Convertible
        Going to try and contact Anti-Venom off Parsons and MLK Blvd. I'll see what he says and buy the hptuners add on for his suite.
          No one knows? I'm just going to go with the ZZP recommendations then because my block is in great shape.
