I did some searching through the forums already on this topic and I've noticed some people have mentioned they knew how to test the ignition control module. My car hasn't been running right and as part of my search for an answer I took off the coils to test them and the connection points from the ICM to the ECM. The coils were ok and the connection points that I knew of were ok but after I put everything back together I can't even get the car to start. At first when I turned the key I didn't get anything... I had power on everything else but the starter never budged. I just took the ICM again then to inspect it some more and after putting it back together I did get the engine turning but the car still wouldn't start and after trying a couple of times to get it going all of a sudden it stopped turning over and went back to nothing like the first time. Anyway I'm suspecting that the ICM is my problem but I would like to know for sure before I go out and spend money on a new one so if someone could tell me how to test it or give me a schematic that shows every connection in detail (I have one now but it doesn't show where all of the connections go) it would be greatly appreciated. Thanks.
Testing the ICM
ok how i did mine is i had a haynes manual and you have to have an ohm reader and some paper cips you open the paper clips up and stick them into the back of the holes on the icm and you should get a reading ill trying to get you what charg its supposed to have later today1999 Firebird 3.8 Chamelon<br /><br />MagnaFlow Catback<br /><br />Devon
Well, I'm not sure how you can test it, but i have one that I will sell you for like $12-15 shipped. MY reason for selling it is because i just finished a complete rebuild, and in the process I purchased a new icm, and msd ignition coils. I had no problems with this one, and it is an ac delco. Like i said before the rebuild i had no misfiring, or engine studdering, the car ran great. I would have no problem shipping this thing out to you. let me know.
Holes on the ICM?? I don't recall seeing any holes on it.
White Thunder what are you driving or what did the ICM you have come out of... was it 94 firebird as well?Newfoundlands Camaro & Firebird Enthusiast Site<br /><a href=\"http://www.nf-fbody.com\" target=\"_blank\">www.nf-fbody.com</a>
need help finding a balancer and a replacement balancer bolt. im at a lost after confusing myself researching.4 weeks ago
