is it possible to remove the heads without taking off the valve springs? my mechanic told me that i didnt have to take them off...any imput would be awesome. thanks
removing the heads !
2000 Firebird 3.8 A4 w/W68<br />WS6 Ram Air Hood<br />SSM Port/Polished Heads <br />NOS #05175<br />Accel wires<br />Accel Coil Packs<br />MSD DIS-4 High Output<br />zexel torsen w/3.42<br />SLP CAI<br />Whisper Lid<br />K&N filter<br />JET programmer<br />Hypertech 160 degres thermo<br />Flowmaster cat-back<br />air temperature module<br />Eibach Pro Kit lowering springs<br /><a href=\"http://www.angelfire.com/ar3/projectfalcon/homepage.html\" target=\"_blank\">www.angelfire.com/ar3/projectfalcon/homepage.html</a>Tags: None
Your mechanic is correct. Just take off the rockers, and the pushrods.
Don't forget to label them when removed. If you are unsure which is intake and which is exhaust. Label them front to back on each bank in a simple code... 1A 1B, 3A 3B, 5A 5B etc.<b>15.41</b> @ 89.80 & 15.45 @ <b>91.64</b>, 2.21 60ft, 3,440 raceweight, using <b>OEM</b> Equipment. <br />\'98 L67/M49 w/ 134,000 miles before spun bearing. \"<i>It\'s all stock, Baby</i>!\"
