3.4 Gurus please help***update*** - FirebirdV6.com/CamaroV6.com Message Board
  • 3.4 Gurus please help***update***
    Well im trying to take off my crank balancer but for some reason it won't give, and yes i took off all the bolts the 4 small ones and the big one in the center im tighting the pulley as much as i can even using a a damn breaker bar [img]graemlins/twak.gif[/img] AND an impact wrench :mad: but some how it won't come out am i missing something???? any info. would be greatly appreciated.
    [ May 01, 2004, 02:09 AM: Message edited by: pontiac nino ]
    ---Niño---<br /><i>95\' silver 5 spd</i>
    i had the same prob i striped out my puller and then i went a rented one from auto zone put it on and used a impacted and it came right off do you have the little tip on the end or is it straight bolt?
    1995 Camaro 3.4 M5 - Project<br />1998 Camaro 3.8 A4 - Daily<br />Aim:V6OnSpeed<br /> <a href=\"http://www.cardomain.com/memberpage/576233/1\" target=\"_blank\">http://www.cardomain.com/memberpage/576233/1</a>
      it's a claw actually and has a straight bolt you think that could be the prob?
        is it possible for the balancer to break cuz i feel it very tense like if it wants to give if i tighten it anymore, can i just bang it out w/ a hammer?
          oil up the balancer, put a puller on it and tighten it up and hit the crank ballancer with a hammer.
          It should come off.
          \'85 Z28, T-tops new LG4 and TH700<br />\'85 3.4L 5-speed<br />mods: <a href=\"http://www.cardomain.com/id/oil_pan_4\" target=\"_blank\">http://www.cardomain.com/id/oil_pan_4</a> the nitrous exhaust O2 safety, pg 3. <br />Areo space materal engineer wantabe
            mine didnt give me any problems.. just put the pulley puller on it and it came right out
              think im gonna go rent a pulley tommorrow one that has a moving tip cause the pulley i have now is starting to strip
                For future kowledge info. id thought id let you guys know i rented a pulley w/ a rotating tip and it out immediately WTF? well like new2thegame said my original puller just got stripped out from trying to turn inside the the crank.
                I strongly recommend using a pulley w/ bolts and a rotating tip instead of a pulley in the form of a claw.
                THANKS MOFO'S FOR ALL THE HELP! [img]graemlins/rock.gif[/img]
                  yea i went and rented it from auto zone and it came right out
