Ripped my engine apart today. My oil pressure had dropped and I heard a tapping so i ripped the oil pan off and discovered that i had spun the #1 cylinder, connnecting rod bearing. It ruined my crank and bearings! So no im debating on whether to buy a new motor, maybe any LS1, or try to find a new crank or v6. So if anyone has a motor laying around they're not using, let me know!!
Spun rod bearing!! Need help!!
_davjos81- 02 v6<br /><a href=\"http://www.cardomain.com/id/davjos81\" target=\"_blank\">www.cardomain.com/id/davjos81 </a><br /><a href=\"http://community.webshots.com/user/davjos81\" target=\"_blank\"> <a href=\"http://community.webshots.com/user/davjos81\" target=\"_blank\">http://community.webshots.com/user/davjos81</a> </a> <br /><br />-over $8,000 invested! Too many mods to list, just check out my site!!Tags: None
i bet some trash got down into the motor when you were doing the swap, you can probably save the crank thats in the car, just get the crank ground, and buy some +.010 bearings...<b>Black</b> 1998 Pontiac <i>Firebird</i> A-4 swap<br />271.4rwhp/259.4rwtq NA<br />13.30@102.44 <br /><a href=\"http://www.freewebs.com/wickedsix98\" target=\"_blank\">www.freewebs.com/wickedsix98</a>
how do you "spin" a bearing? how do you avoid doing it?96 Camaro M5. Dark metallic gree (?dont know the offical color name)<br />Home made Intake :: Headers, 3inch headers back to Flowmaster muffler :: spec stage 3 clutch Now installed, waiting for 3.42\'s and LSD next month<br /><a href=\"http://photobucket.com/albums/y192/RiceEatingCamaro/?action=view¤t=newcar.jpg\" target=\"_blank\">My Car</a> <br /><br />Totalled Car.<br /><a href=\"http://bellsouthpwp.net/s/k/sk8er305/\" target=\"_blank\">96 CamaroRS</a>
a spun bearing is when the little grooves in the block or on the bearing give out and the bearing "spins" in the rod or the block, it tears up the crank and normally if you spin a main bearing the block has to be align bored...<b>Black</b> 1998 Pontiac <i>Firebird</i> A-4 swap<br />271.4rwhp/259.4rwtq NA<br />13.30@102.44 <br /><a href=\"http://www.freewebs.com/wickedsix98\" target=\"_blank\">www.freewebs.com/wickedsix98</a>
Take it to the machine shop.... they might be able to fix that. However, for the price of maching you could prob. just replace the entire bottom end of the motor with a junkyard 3.8.
When life gives you lemons make lemonade right. Like you mentioned, now you have a perfect excuse to swap in a LS1.
Originally posted by wantmorepower:
When life gives you lemons make lemonade right. Like you mentioned, now you have a perfect excuse to swap in a LS1._davjos81- 02 v6<br /><a href=\"http://www.cardomain.com/id/davjos81\" target=\"_blank\">www.cardomain.com/id/davjos81 </a><br /><a href=\"http://community.webshots.com/user/davjos81\" target=\"_blank\"> <a href=\"http://community.webshots.com/user/davjos81\" target=\"_blank\">http://community.webshots.com/user/davjos81</a> </a> <br /><br />-over $8,000 invested! Too many mods to list, just check out my site!!
Used 3.8 engines are cheap. Go that route, or um get a zzp stroker kit. They are gonna regrind the crank anyways.Keith - 99 'maro - White M5 - bumpstick and boltons - 13.65 @ 101 N/A
http://seppo.hopto.org/
1500 is a lot for a stroker kit that only going to give me another 20ish hp, plus i cant use nitrous or boost w/ it._davjos81- 02 v6<br /><a href=\"http://www.cardomain.com/id/davjos81\" target=\"_blank\">www.cardomain.com/id/davjos81 </a><br /><a href=\"http://community.webshots.com/user/davjos81\" target=\"_blank\"> <a href=\"http://community.webshots.com/user/davjos81\" target=\"_blank\">http://community.webshots.com/user/davjos81</a> </a> <br /><br />-over $8,000 invested! Too many mods to list, just check out my site!!
You should be alright as long as you don't spray a 150 shot. But then again anytime you juice you are risking gernading anyways. But based on ZZP's results you would be fine as long as you did not spray more than 100 shot.Keith - 99 'maro - White M5 - bumpstick and boltons - 13.65 @ 101 N/A
look on ebay you can useally get a used one off there for like 500
or talk to www.TAcreationsusa.com they have all year 3.8 motors and if not they can help you track one down got to there web site and give them a callwww.turbov6camaro.com
1997 3800 Series II Camaro
Get a used crank with no damage cut/polished and put new rings and bearings in the engine. No reason to replace the entire bottom end....just fix what broke. Shouldn't cost much.\"Since I started working, every single day has been worse than the day before, so that every day you see me is the worst day of my life\"
For the amount of work it would take to replace the crank and rebuild the bottom end of the motor, it would be cheaper and faster to just throw in a junk yard motor.Keith - Chicago<br /><a href=\"http://www.hptuners.com\" target=\"_blank\">HP Tuners - PCM Reprogramming</a><br /><a href=\"http://www.dxsoftware.com/magnus/\" target=\"_blank\">97 Firebird V6 to LS1 swap</a><br /><b>V8 9.967@132.78</b> 1.322 60\' NA Heads/Cam<br /><b>V8 10.295@128.48</b> 1.363 60\' NA Cam Only<br /><b>V8 10.987@119.31</b> 1.422 60\' NA Stock Internals<br /><b>V6 13.674@98.22</b> NA<br /><b>V6 12.394@104.91</b> N20 100HP
