I just recently bought new head bolts. Tourqued them down, started the car, head leaked water. Turned car off pulled heads. Do I need to buy new head bolts or will these be ok to reuse?
Head Bolts
The safe answer would be no. If you are using the factory size 10mm head bolts, my answer would still be no. However if you've installed say a 13-15mm head bolt following the ssm swap, i'd say yes. But check each bolt with a micrometer to make sure that no stretching has occured.98 NOS\'d Camaro 3.8 A4<br />99 Hyundai Elantra 2.0 A4
Contact ARP to have some head studs made...that way, you won't have to replace the head bolts again.- Josh<br />If you have any questions or need installation pics/help, e-mail me: Viper98885@aol.com<br /><a href=\"http://Camaroz28.cardomain.com/id/viper98885\" target=\"_blank\">\'93 Camaro Hardtop</a><br /><a href=\"http://Camaroz28.cardomain.com/id/01lincolnls8\" target=\"_blank\">\'01 Lincoln LS8 Sport</a><br />\'00 Yamaha YZF-R6<br /><a href=\"http://www.ftpp.net\" target=\"_blank\">Full Throttle Performance</a>
<blockquote>quote:</font><hr>Originally posted by viper98885:
Contact ARP to have some head studs made...that way, you won't have to replace the head bolts again.<hr></blockquote>
I thought about that, but wouldn't that make it pretty tuff to get the heads on/off with the engine still inside the car?
Yes, you need new bolts. They have been stretched and can't be properly torqued to spec.
DEE1997 GTP(13.3@104)-Sold<br />1999 Trans Am M6
I had no problems whatsoever with my head studs. If anything, it makes it easier because you get your bolt holes lined up and the head will slide right down. From there, torque the nuts and you're set.- Josh<br />If you have any questions or need installation pics/help, e-mail me: Viper98885@aol.com<br /><a href=\"http://Camaroz28.cardomain.com/id/viper98885\" target=\"_blank\">\'93 Camaro Hardtop</a><br /><a href=\"http://Camaroz28.cardomain.com/id/01lincolnls8\" target=\"_blank\">\'01 Lincoln LS8 Sport</a><br />\'00 Yamaha YZF-R6<br /><a href=\"http://www.ftpp.net\" target=\"_blank\">Full Throttle Performance</a>
by 2.8 BirdI wish you guys the best for you and your family. Good health, happiness and prosperity. Merry Christmas and a happy new year....3 days ago
by ssms5411Just ordered some Toyo 315/35/17 tires for my 17x11 rims. Hopefully I can get them on the beginning of next year. Will post pics.3 days ago
by ssms5411Haven’t done anything on the Camaro, but put LEDs on my truck headlights . And my oil pressure sensor went out on the truck so going to fix that this...1 week ago
