I have ordered the maft+ and next week ordering the cam the vavle springs and retaining locks and timing chain and gasket set. Where can i get the timing chain and gasket set. and how much do they run. Is there any other thing i need.
when getting a cam what all do i need
<b><a href=\"http://www.sick-sixx.com\" target=\"_blank\">SICK-SIXX MEMBER</a></b><br />NA 14.345 with a 1.863 60 foot<br />Nitrous 13.03@99.5 with a 1.63 60 foot<br /><br />2000 Camaro 3.8L A4: USE TO HAVE Comp Cam 210/220 .535/.547 113lsa 111 I/C, Port and Polished Heads, NX Wet Kit 100 Shot, CPRA made by CP, RK Sport HeadersTags: None
which cam are you getting?
Dont forget rocker arm bolts. They stretch so they are 1 time use is what I have been told.
Depending on cam you might need different length pushrods. Its probly a good idea to measure once you get the cam in.
Stuff you will need:
24503515 – Rocker Bolts 12 .75(ea)
24504668 – Timing Chain 35.71
24502252 – Timing Cover Gasket 4.17
12537616 – Upper/Lower Intake Gasket Kit 23.07
24502433 – Thermostat Gasket .97
24503432 – Throttle Body Gasket 3.44
½ - 20x4 Fine Thread – Bolt to thread in cam for removal/install.
Tools needed:
Pulley remover tool (steering wheel remover tool will work)
Pulley installer tool
½” or ¾” Impact gun
15/16 impact socket for crank pulley bolt
1 and 1/8 impact socket for cam gear bolt
Plastic fuel line removal tool
You can order parts from Dal at Vandevere Olds for a discount.
http://www.vandevere.com
800-362-9494 ext 501 or email him at:
lockitup@bright.net
I think there is a gasket kit that includes the head gaskets also but I didn't do heads so I'm not sure of the part #.
FYI the bolt on the crank can be a SUPER PITA so if you don't have a mega impact gun and a good size compressor you might want to take it to a shop to have them loosen it up.Michael Huff<br />92 RS, 98 V6, 97 SS, 00 Z28 <br /> <a href=\"http://www.carolinafbodyclub.com/\" target=\"_blank\">http://www.carolinafbodyclub.com/</a>
Thanks alot guys i should have all the parts within two to 3 weeks hopefully i will keep you updated and like ironman i will post a video clip and some dyno numbers.<b><a href=\"http://www.sick-sixx.com\" target=\"_blank\">SICK-SIXX MEMBER</a></b><br />NA 14.345 with a 1.863 60 foot<br />Nitrous 13.03@99.5 with a 1.63 60 foot<br /><br />2000 Camaro 3.8L A4: USE TO HAVE Comp Cam 210/220 .535/.547 113lsa 111 I/C, Port and Polished Heads, NX Wet Kit 100 Shot, CPRA made by CP, RK Sport Headers
He forgot Beer and Pizza :)
The pully remover/installer acan be rented at Autozone for free.
if you can't find a fuel line tool they are easily made with plastic froma gallon milk bottle.94 Quasar Blue Z28<br /><a href=\"http://www.9t4z28.com\" target=\"_blank\">http://www.9t4z28.com</a><br /><a href=\"http://www.9t4z28.com/Dyno1.htm\" target=\"_blank\">http://www.9t4z28.com/Dyno1.htm</a>
Hello every one, ozzy here ive been looking at this page for weeks now finally joined. So my question is why is it that every turbo build forum just ends...21 hours ago
by 2.8 BirdI wish you guys the best for you and your family. Good health, happiness and prosperity. Merry Christmas and a happy new year....5 days ago
by ssms5411Just ordered some Toyo 315/35/17 tires for my 17x11 rims. Hopefully I can get them on the beginning of next year. Will post pics.5 days ago
