I have ordered the maft+ and next week ordering the cam the vavle springs and retaining locks and timing chain and gasket set. Where can i get the timing chain and gasket set. and how much do they run. Is there any other thing i need.
when getting a cam what all do i need
<b><a href=\"http://www.sick-sixx.com\" target=\"_blank\">SICK-SIXX MEMBER</a></b><br />NA 14.345 with a 1.863 60 foot<br />Nitrous 13.03@99.5 with a 1.63 60 foot<br /><br />2000 Camaro 3.8L A4: USE TO HAVE Comp Cam 210/220 .535/.547 113lsa 111 I/C, Port and Polished Heads, NX Wet Kit 100 Shot, CPRA made by CP, RK Sport HeadersTags: None
which cam are you getting?
Dont forget rocker arm bolts. They stretch so they are 1 time use is what I have been told.
Depending on cam you might need different length pushrods. Its probly a good idea to measure once you get the cam in.
Stuff you will need:
24503515 – Rocker Bolts 12 .75(ea)
24504668 – Timing Chain 35.71
24502252 – Timing Cover Gasket 4.17
12537616 – Upper/Lower Intake Gasket Kit 23.07
24502433 – Thermostat Gasket .97
24503432 – Throttle Body Gasket 3.44
½ - 20x4 Fine Thread – Bolt to thread in cam for removal/install.
Tools needed:
Pulley remover tool (steering wheel remover tool will work)
Pulley installer tool
½” or ¾” Impact gun
15/16 impact socket for crank pulley bolt
1 and 1/8 impact socket for cam gear bolt
Plastic fuel line removal tool
You can order parts from Dal at Vandevere Olds for a discount.
http://www.vandevere.com
800-362-9494 ext 501 or email him at:
lockitup@bright.net
I think there is a gasket kit that includes the head gaskets also but I didn't do heads so I'm not sure of the part #.
FYI the bolt on the crank can be a SUPER PITA so if you don't have a mega impact gun and a good size compressor you might want to take it to a shop to have them loosen it up.Michael Huff<br />92 RS, 98 V6, 97 SS, 00 Z28 <br /> <a href=\"http://www.carolinafbodyclub.com/\" target=\"_blank\">http://www.carolinafbodyclub.com/</a>
Thanks alot guys i should have all the parts within two to 3 weeks hopefully i will keep you updated and like ironman i will post a video clip and some dyno numbers.<b><a href=\"http://www.sick-sixx.com\" target=\"_blank\">SICK-SIXX MEMBER</a></b><br />NA 14.345 with a 1.863 60 foot<br />Nitrous 13.03@99.5 with a 1.63 60 foot<br /><br />2000 Camaro 3.8L A4: USE TO HAVE Comp Cam 210/220 .535/.547 113lsa 111 I/C, Port and Polished Heads, NX Wet Kit 100 Shot, CPRA made by CP, RK Sport Headers
He forgot Beer and Pizza :)
The pully remover/installer acan be rented at Autozone for free.
if you can't find a fuel line tool they are easily made with plastic froma gallon milk bottle.94 Quasar Blue Z28<br /><a href=\"http://www.9t4z28.com\" target=\"_blank\">http://www.9t4z28.com</a><br /><a href=\"http://www.9t4z28.com/Dyno1.htm\" target=\"_blank\">http://www.9t4z28.com/Dyno1.htm</a>
by 2.8 BirdI wish you guys the best for you and your family. Good health, happiness and prosperity. Merry Christmas and a happy new year....4 days ago
by ssms5411Just ordered some Toyo 315/35/17 tires for my 17x11 rims. Hopefully I can get them on the beginning of next year. Will post pics.4 days ago
by ssms5411Haven’t done anything on the Camaro, but put LEDs on my truck headlights . And my oil pressure sensor went out on the truck so going to fix that this...1 week ago
