So who where likes to talk cam specs, valve lift, clearances and tolerances?
So far I only know of Michael Huff and I.
We have been talkign for months about what kind of lift I should go with on my custom grind, but nobody has any kind of lift specs regarding clearances.
Here is what we know:
Stock:
182/190 115 LS 111 IC
Camshaft Intake Lift: 0.250 in
Camshaft Exhaust Lift: 0.255 in
Intake Lift: 0.413 in
Exhaust Lift: 0.408 in
SuperSix:
210/214 112 LS 108 IC (RiceCooker)
Camshaft Intake Lift: 0.281 in
Camshaft Exhaust Lift: 0.281 in
Intake Lift: 0.450 in
Exhaust Lift: 0.450 in
Stock Rocker Ratio: 1.6:1
With stock springs, its unsafe to go past .450 valve lift. To fix this, I have purchased springs from Thrasher that will allow me up to .506 lift safely.
I was looking to go with 214/214 112 .500/.500 but is there clearance for .500 @ 214 degrees of duration? I am not to fond of the idea of a valve-piston conflict.
So who has pulled off their heads and knows TDC Piston to deck clearance? Or who knows Valve clearances for the stock setup?
I doubt anyone knows this but I decided to post this just to feed the minds of the curious. If we had an advanced tech section, this would be a great post for that secton. [img]smile.gif[/img]
I believe Thrasher might have some of this info but I still haven't been able to get a hold of them.
One of Thrashers resellers told me he sold 206/212 114 .480/.487 to an L36 guy.
As soon as I find any of this info out, I'll keep you guys posted and hopefully the tech database will be updated with this info.
But there has to be someone out there with more specifics info on this as well. What about GM mechanics or ... anyone at all?
The joy of being a test guy. [img]graemlins/wavey.gif[/img]
Stock:
SuperSix:
