http://www.mymilkexpired.com/tempsto...takevally1.jpg
http://www.mymilkexpired.com/tempstor/guest/mixture.jpg
http://www.mymilkexpired.com/tempstor/guest/nasty1.jpg
http://www.mymilkexpired.com/tempstor/guest/nasty2.jpg
My motor started to run crappy it was only driven for 2 miles with oil like that. I have since found the reason why it happened and fixed it as well as some other problems i was having. I replaced all the gaskets and stuff. The problem ended up being the water pump gasket had cracked and oil was leaking into the collant passenges.
So all new gaskets some motor flush and 3 sets of oil we will see if the car will be back running at the track again.
[ July 24, 2003: Message edited by: slacker69 ]
[ July 24, 2003: Message edited by: slacker69 ]</p>
