i put headers on, burned up a brand new msd wire, put stock one back on, but my SES light is still on, how come? the wire burned on on my header, i fixed that problem, so why is the light on?
spark plug wire replaced, SES LIGHT STILL ON
Hard to say why without knowing the exact code. Get it scanned to find out what it's saying.
Also remember that it takes a few cycles for the PCM to realize the problem has been fixed. Fixing the problem will not turn the SES off right away.Matt
1998 Mystic Teal Camaro M5
yea i got high flow cat, i know u can reset the computer, how? i remember how to reset the CHANGE OIL light, but what about the SES light, how to reset? cus if somthin is wrong, it wil come back up in the same day im sure right?2000 3.8 Camaro M5<br /><br /> <a href=\"http://www.cardomain.com/ride/832316\" target=\"_blank\">http://www.cardomain.com/ride/832316</a>
Pull the PCM BAT, and the PCM IGN fuses for like 30 seconds.
Take it to autozone to get scanned.
If its something like CATylitic inefficiency error(forget the code) its realted to your high flo cat.
You might need a 02 sim or tune to delete the code.
Get the code scanned, and if you have a problem where you shut the car off and start it again and the code disapears, leave teh car on and have them check it with the car on and the code on.-Eric<br /><a href=\"http://www.cardomain.com/id/mustangeater82\" target=\"_blank\">2000 NBM V6 Camaro 5-speed</a> T-top <i>converted</i><br /><b>14.467@95.45mph</b> <i>$0 in mods</i><br /><i>The member formerly known as MustangEater8251</i>
IF I DISSCONNECT THE BATTERY FOR 15 MIN WIL THAT WORK? GUY AT WORK SAID JUST DISCONNECT THE BATT FOR ABOUT 15 MIN, THANKS FOR ALL YOUR HELP, ALL SUGJESTIONS IM GONNA TRY, BUT IM TRYIN TO NOT SPEND MONEY FIRST CUS IM BROKE, BUT IF I HAVE TO I WILL2000 3.8 Camaro M5<br /><br /> <a href=\"http://www.cardomain.com/ride/832316\" target=\"_blank\">http://www.cardomain.com/ride/832316</a>
Get the code scanned, and if you have a problem where you shut the car off and start it again and the code disapears, leave teh car on and have them check it with the car on and the code on.1995 Pontiac Firebird
i put the new wire on, drove around for about 20 min, by the time i got home, i realized the light went away, so i think when i burned up the first wire and it was missing real bad and the light came up, then changed wires, just took alittle bit to recognize that my **** aint broken2000 3.8 Camaro M5<br /><br /> <a href=\"http://www.cardomain.com/ride/832316\" target=\"_blank\">http://www.cardomain.com/ride/832316</a>
