wich ones should i get for N/A 3.8, i have msd wires, and getting an msd ignition, so wich plugs do i go with?
spark plugs
im still thrown off, if i run msd ignition , msd wires, wich spark plugs do you guys recommend?.60? where do i find that, i was looking at thunderracing.com again, and found "NGK TR55-IX Iridium Spark Plugs, Stock heat range, gapped at .050 " wich said was used on my car, but with my car having only airflow mods and hpp3 wich spark plugs should i use? and i heard its a big noticeable difference when going to msd ignition and changing wires and spark plugs, that true?2000 3.8 Camaro M5<br /><br /> <a href=\"http://www.cardomain.com/ride/832316\" target=\"_blank\">http://www.cardomain.com/ride/832316</a>
Buy the AC Delco plugs or NGK. NGK makes the AC Delco professionals which are an iridium plug. I've been running the delco professional's in my car for the past 40k+ with no problem..and if its an iridium plug like the TR55ix do not gap it yourself, they are set at the factory.-1999 Camaro Coupe 3800 Series II V6 A4 - SOLD<br />-1998 Pontiac Grand Prix GTP coupe
http://www.thunderracing.com/catalog...vid=5&pcid=102
, all have different gaps, i kinda feel stupid now for asking and asking, but there are different gaps.... im learning....
he said they are set at the factory, well is that the .50 gap? or the .35, .40, thanks again guys
[ August 06, 2005, 01:42 PM: Message edited by: Chris Camaro ]2000 3.8 Camaro M5<br /><br /> <a href=\"http://www.cardomain.com/ride/832316\" target=\"_blank\">http://www.cardomain.com/ride/832316</a>
