Longevity of L36 in conjuction with aftermarket parts - FirebirdV6.com/CamaroV6.com Message Board
  • Longevity of L36 in conjuction with aftermarket parts
    ok I have about 100k on my L36 right now. I know my engine wont last forever, but if i went with some new heads, camshaft, springs, maybe the supersix package, basically the whole valvetrain, would that be like running with a new engine? I of course would be using the same stock 231 block
    SLP CAI, RK Sport headers, P&Ped heads and intake, GT2 cam, Upgraded valvetrain, Z28 rear axle with 4.10s Tx Spd tune, Z06 rims, 2.5\" exhaust to flowmaster, 160* thermo, B&M ripper, upgraded ignition, rockford fosgate 12\" with sony xplode amp and HU.
    With 100K on the engine you're probably okay but personally I would install BRAND NEW headgaskets on it when you go to change the cam/valvetrain and put stress on the engine.
    Might as well put a new waterpump in it for good measure, change out the timing gear set and chain, and just essentially rebuild the tophalf "just in case" if you decide to tear it open.
    2002 5-spd NBM Camaro
    Details: www.1lev6.com
      if I do all that u mentioned, will that make my engine close to brandnew so I wont have to worry about high mileage?
        yep! but then you will have to worry about the little things like maybe a starter and water pump if they havent gone out already.
          <blockquote>quote:</font><hr>Originally posted by nino:
          yep! but then you will have to worry about the little things like maybe a starter and water pump if they havent gone out already.<hr></blockquote>
          I mentioned the waterpump [img]smile.gif[/img]
          But yes... it will make everything which generally fails, sans valve guide seals, new.
            Keep up on regular service intervals, you shouldnt ever have to worry about the bottom end unless you are REALLY thrashing it.
            Brendan
            2000 Camaro L36
            5-speed
            I am a man, I can change... if I have to.... I guess.....<br /><br />-Red Green
              What about Piston Rings??? You tend to wear these out in higher mileage cars.. I mean not to where the car won't run, but probably enough so that it wouldn't run "Like New"...
              [ July 28, 2003: Message edited by: AZ3.8Camaro ]</p>
              1997 Dodge Viper GTS
                how much are piston rings??? are they worth getting
                  <blockquote>quote:</font><hr>Originally posted by FuryCharger:
                  how much are piston rings??? are they worth getting<hr></blockquote>
                  You don't need new piston rings...
                    I have 120K on mine and it still's running strong. I personally would deffinately replace all the seals/bearings if I were to put an agressive cam in.
