my dad wants to trade my 99 a4 in for an SS... Would it be a bad idea to do an ls6 conversion instead? has it been done? will it be faster then an ss?
LS6 or get an SS
Uhm, depending on what year SS you get, it could be an LS6 anyway [img]smile.gif[/img] If you don't know if you can handle the conversion, chances are that you cannot. So buy the SS instead, and save the headache.<a href=\"http://www.fullthrottlev6.com\" target=\"_blank\">www.fullthrottlev6.com</a> THE SOURCE!
the ls6 won't fit in the camaro engine bay. You would have to chop the frame and extend it about a foot I blieve. That means new custome made fenders and hood, possibly front bumper cover made. Not to mention all the electrical and possible drive train work. Like tranny driveshaft and rearend. Plus suspension and all the other things that you might have to swap to get it to work. In the long run just get the SS.
Excuse me? I've seen it. I worked at an LS1/LS6 speed-shop for a year. Some did, check the casting numbers. Also, it is those components that make the combo stronger, not the block anyway. If you ever get the chance to see a Darton sleeved block, chances ae it's the LS1 not LS6 because Darton believes them to be stronger in such instances.
Also, the LS1 and LS6 blocks have the same dimensions...Now GM even has one part number to cover both, instead of two seperate part numbers (meaning if you go to buy a new block now, you are getting an LS1/Ls6 block, and can only get it that way unless they have one of the old ones laying around).
Anything else?<a href=\"http://www.fullthrottlev6.com\" target=\"_blank\">www.fullthrottlev6.com</a> THE SOURCE!
do the swap.
i am all about swapping!
if it hasnt been done on here then you can be the first. and just imagine all the people who will want to follow your steps.6s.......under the hood or under the belt, they just dont cut it.
Anything else?
And yes I'm aware of the similarities, I've helped with installing heads on both.
Just so we're on the same level, I am talking about COMPLETE LS6 engines. I'm aware LS6 blocks were in a few later models.
[ September 13, 2004, 02:14 AM: Message edited by: WishIHad$$$ ]2001 Black Z28 M6<br />Sprayed, slotted, geared and more~
Originally posted by crasher:
the ls6 won't fit in the camaro engine bay. You would have to chop the frame and extend it about a foot I blieve. That means new custome made fenders and hood, possibly front bumper cover made. Not to mention all the electrical and possible drive train work. Like tranny driveshaft and rearend. Plus suspension and all the other things that you might have to swap to get it to work. In the long run just get the SS.-Chris<br />2001 Pewter Camaro M5<br />Current Mods: NOS Dry Kit and a few others<br />N/A: 15.5@88.9MPH<br />N2O: ??? <br /> <a href=\"http://www.cardomain.com/id/jtusa69888\" target=\"_blank\">http://www.cardomain.com/id/jtusa69888</a>
Originally posted by AZv6camaro:
</font><blockquote>quote:</font><hr />Originally posted by crasher:
the ls6 won't fit in the camaro engine bay. You would have to chop the frame and extend it about a foot I blieve. That means new custome made fenders and hood, possibly front bumper cover made. Not to mention all the electrical and possible drive train work. Like tranny driveshaft and rearend. Plus suspension and all the other things that you might have to swap to get it to work. In the long run just get the SS.</font>[/QUOTE]He must be thinking LT5...
the ls6 won't fit in the camaro engine bay. You would have to chop the frame and extend it about a foot I blieve. That means new custome made fenders and hood, possibly front bumper cover made. Not to mention all the electrical and possible drive train work. Like tranny driveshaft and rearend. Plus suspension and all the other things that you might have to swap to get it to work. In the long run just get the SS.</font>[/QUOTE]w3rd, the dimensions of the LS1 and LS6 are the same and i know LS1's fit in 4th gens.... [img]graemlins/stickpoke.gif[/img]
-Aaron, AKA ATL2001<br />93 3.4L <br /><a href=\"http://www.ilfba.com\" target=\"_blank\">www.ilfba.com</a>
Originally posted by StudlyCamaro:
</font><blockquote>quote:</font><hr />Originally posted by AZv6camaro:
the ls6 won't fit in the camaro engine bay. You would have to chop the frame and extend it about a foot I blieve. That means new custome made fenders and hood, possibly front bumper cover made. Not to mention all the electrical and possible drive train work. Like tranny driveshaft and rearend. Plus suspension and all the other things that you might have to swap to get it to work. In the long run just get the SS.</font>[/QUOTE]w3rd, the dimensions of the LS1 and LS6 are the same and i know LS1's fit in 4th gens.... [img]graemlins/stickpoke.gif[/img] </font>[/QUOTE]thats what I was always told wether its true or not I have no idea.
